Fuel shut off soelinoid
Postby cummins32 » Mon Oct 01, 2012 8:47 pm
Well, I went to shut my truck off and the key wouldn't kill it, so I popped the hood and grabbed the manual kill and it wouldn't do anything, so I turned my key back to on and tried it again and it dropped the idle, but wouldn't kill it so I blocked the air to the turbo to kill it. Well on the way home, if I gave it any more than half throttle, it would start missing, and pour out white smoke and I lost all power to my cab, my radio quit working, and none of my gauges in my cluster would work. So, My pump is shot correct ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Fuel shut off soelinoid
Postby BC847 » Mon Oct 01, 2012 9:02 pm
cummins32 wrote: My pump is shot correct ?
No.
It sounds like multiple issues, not related to one another, are showing their heads at the same time. :shock:
Postby cummins32 » Mon Oct 01, 2012 9:18 pm
what do you think it is ? I'm just thinking the pump is junk because the manual kill won't shut it off and the fuel shutoff is junk and lodged in the pump somewhere
cummins32
Postby fatty » Mon Oct 01, 2012 9:56 pm
Has the manual shutoff worked before? It might need re indexed. It's got splines one it just like the throttle shaft.
Postby Tacoclaw » Tue Oct 02, 2012 4:41 am
Yeah, it sounds like you chipped your tip, then possibly knocked off your FSS wire while you we're checking things out and it shorted on something.
Fatty's on the right track with the manual lever, has your pump been apart before?
Postby cummins32 » Tue Oct 02, 2012 6:52 am
What would cause it to start missing and smoking white, and the pump top was off once when I installed a 3200 spring
cummins32
Postby cummins32 » Tue Oct 02, 2012 6:54 am
Also what tip ?
cummins32
Postby Tacoclaw » Tue Oct 02, 2012 8:02 am
The FSS tip, and these injection systems are simple compared to newer stuff, but still need things to be right. It could be something like a piece of rubber stuck somewhere not letting fuel through at the right time, so it retards that injection event causing white smoke and/or a miss. It's not a guarantee, but it is a possibility. I'd pull your FSS and see how bad the tip is chewed up.
Regardless, I don't think you trashed your pump.
Postby cummins32 » Tue Oct 02, 2012 8:52 am
Ok, I'll try that
cummins32
Postby PToombs » Tue Oct 02, 2012 4:46 pm
And the missing and white smoke can be from the power loss. Just because the tip of the plunger is chipped, if there is no power to the solenoid, it will still restrict fuel enough to cause it to run bad.
Postby cummins32 » Tue Oct 02, 2012 8:34 pm
Well, I got the solenoid out and the tip was chewed up, so I pulled the rubber off and the spring, so tomorrow I'm gonna put it back together and hope for the best, I drained the fuel out of the pump also to try and get the crud out, so I'll need to fill that back up correct ?
cummins32
Postby cummins32 » Wed Oct 03, 2012 9:30 pm
Well, I put it back together tonight, and I tried firing it up and it just cranks, so I cracked open one of the injector lines and it's barely putting out any fuel ? could the pump be bad ?, My indexing might be off also though, so I think I need to tear it back apart and try and change it.
cummins32
Postby slow_90firebird » Wed Oct 03, 2012 9:35 pm
My truck had the same problem except that it ran fine and the idle never dropped after i turned the key off... I ordered a new solenoid from ebay for a VW application it was like 12 dollars. Worked mint. Such a pain to get out though I had to use a chisel to make a notch in the old one and spin it out, and the new one went in the same way haha.
Also my shutoff lever wouldnt kill the engine either. They were right - it just needs to be adjusted. Actually I think there might have been a stop that it was hitting and I adjusted that or moved it I cant remember. But it worked fine untill I turned up the power screw, then it wouldnt kill the engine any more.
slow_90firebird
Postby PToombs » Thu Oct 04, 2012 4:49 pm
Cummins 32, leave the plunger and spring out of the solenoid then try starting it. If it runs the solenoid is bad. Most guys cut the top of the bracket off that's on the head of the pump for better access to the solenoid.
Postby cummins32 » Thu Oct 04, 2012 5:38 pm
Got it runnin, runs good but I have some white smoke when I rev it up
cummins32
