Pushrod Cover Gasket replace?
Postby Doge Ram 350 » Tue Oct 16, 2012 5:21 am
My ride a 1993 Dodge Ram D350 Cummins. Is it possible to change the pushrod cover gasket without pulling the injection pump?
Doge Ram 350
Re: Pushrod Cover Gasket replace?
Postby Philip » Tue Oct 16, 2012 9:38 am
No
There is one bolt behind the injection pump. If by some chance you did get it out. You wouldn't be able to get it back in.
Postby Doge Ram 350 » Tue Oct 16, 2012 10:13 am
Mhh :? I want to pull off the Engine . In this case it is easier?
Doge Ram 350
