IP leaking when cold...Where?
Postby 93DodgeCummins » Fri Nov 23, 2012 7:35 pm
I started my pickup up this morning and noticed it started dripping. It looked like it was coming from the middle section of the pump from the back side. Once the engine got warmed up some it quit leaking. Is there a common place for leaks on the engine side of the pump when it gets cold?
heres the pics:
http://s1255.beta.photobucket.com/user/ ... 8967292605
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: IP leaking when cold...Where?
Postby Mark Nixon » Sun Nov 25, 2012 9:39 am
On the back side there is an oval-shaped plate that is sealed with an 'O'-ring, which tends to leak on our well-aged trucks.
It will require removing the pump.
The plate that has the 'O'-ring under it is the gold colored one, near the bottom of the pump, in this pic:
Postby 93DodgeCummins » Sun Nov 25, 2012 11:31 am
Thanks I was wondering what was on the other side. I suppose i have a big project coming up....
EDIT: Is there any way to fix it without pulling the whole pump?
93DodgeCummins
