trucks running hotter than normal
Postby blackvmax07 » Tue Nov 27, 2012 6:49 am
well the other day my battery fell into my fan shroud and demolished it, ever since my truck has been running at the 3/4 quarter mark on the engine temp, where should the needle be while driving or towing? Cant seem to find a new shroud anywhere, can someone direct me somewhere? Thanks
blackvmax07
Re: trucks running hotter than normal
Postby dazedandconfused » Tue Nov 27, 2012 8:32 am
What year truck? Intercooled or not?
Postby blackvmax07 » Tue Nov 27, 2012 6:02 pm
oh sorry its a 92 intercooled
blackvmax07
Postby RCCUMMINS89 » Tue Nov 27, 2012 7:29 pm
Did it rip any of your grounds off when it fell over?
Postby blackvmax07 » Tue Nov 27, 2012 8:07 pm
any grounds off the battery? There was a little wire just hanging after all was said and done but i figured it wasnt anything cause all my lights and stuff worked
blackvmax07
Postby RCCUMMINS89 » Tue Nov 27, 2012 8:18 pm
The ground wires running from your batter to the fender and core support are important for your gauges to work properly. NOT SAYING THAT IS WHAT IT IS, but it can throw the ohms off. These gauges run off ohms, so if there is poor grounds the gauges can fluctuate and read innacurate.
Just something to check.
Postby blackvmax07 » Tue Nov 27, 2012 9:13 pm
that would prob make sence cause the gauge randomly jumps around
blackvmax07
Postby RCCUMMINS89 » Tue Nov 27, 2012 9:23 pm
If the gauge is jumping around, then yes, that is what it would be.
Postby PToombs » Wed Nov 28, 2012 6:08 pm
I would be more inclined to think without the shroud you aren't pulling enough air thru the radiator. The shroud causes the fan to pull thru the whole thing, and without it the fan only pulls thru the middle. The ground wire is very important, but that isn't the whole issue.
Postby RCCUMMINS89 » Wed Nov 28, 2012 6:18 pm
I"ve never ran a shroud on any 1st gen I've owned... never have had any issue.
Postby PToombs » Wed Nov 28, 2012 6:27 pm
I'm basing my thought on 2 things, only 1 gauge is screwing up, and only the shroud is missing. I have heard of other guys running without shrouds also, but who knows what shape the radiator is in. If the fins are getting bad it won't cool as effectively, so more air is better.
By all means, fix the wire 1st, that's easy, then see how it is. I would do the same thing. Especially since I've seen how scarce and expensive shrouds are! ;)
Postby blackvmax07 » Sun Dec 02, 2012 2:29 pm
hey guys reporting back cause i was able to work on the ol dodge last night, i fixed the wire that was messed up and drove the truck around last night and seems my problem is fixed, truck never ran in the hot again
blackvmax07
Postby PToombs » Sun Dec 02, 2012 2:43 pm
Good! It was a simple fix for ya. 8)
Postby blackvmax07 » Mon Dec 03, 2012 4:02 pm
yes sir thanks yalls help, i would have never thought anything of it
blackvmax07
