truck wont start
truck wont start
Postby 1990CTD » Sun Dec 09, 2012 7:06 am
Well I just had an injection pump put on my 90. The pump came off a 93. I heard about ksb switch. The truck started fine when warm yesterday. It sputtered and stuff. This morning it won't start. It cranked and cranked. I need help!!!!
1990CTD
Re: truck wont start
Postby ellis93 » Sun Dec 09, 2012 8:54 am
Sounds like it lost prime,or the kill solenoid either went bad/has a poor connection. Crack an injector line and see if it spits fuel
Postby 1990CTD » Sun Dec 09, 2012 11:30 am
Okay. I went against my code and sprayed a little ether. It started. It white smokes like crazy, sputters and misses. It done same thing yesterday on first startup with new pump. Could it be timing? It sounds different. It hazes bad. It runs fine when warm though????
1990CTD
Postby ihredneck » Mon Dec 17, 2012 10:57 am
What's the story on the injectors? I had my rig out and about and was running fine. Shut down and then tried to start up minutes later with no luck. Chased fuel lines, pick up assembly, injector lines, fuel shutoff...blah blah. Ended up being injectors as I swapped in a spare set and problem was solved.
ihredneck
Postby 1990CTD » Mon Dec 17, 2012 7:48 pm
Ended up being off time. I could still use to adjust it some more.
1990CTD
