Compression brake! :D
Postby bmoeller » Mon Dec 24, 2012 6:05 pm
Can't wait for one of these to come out for us! :D
http://www.youtube.com/watch?v=xT0Ua2ogGJQ
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Compression brake! :D
Postby dazedandconfused » Tue Dec 25, 2012 6:28 am
https://www.youtube.com/watch?v=36uZA_i ... ata_player
Will be out for the 1st gens first I was told.
Postby RumbleFish » Tue Dec 25, 2012 7:35 am
Well, the wife heard this while I was watching and said no way. One the other hand, my dad is now looking for a truck just to put one of these on. What to do....
Postby bmoeller » Tue Dec 25, 2012 7:43 am
PacBrake makes one for the 6.7L engines. :D
http://www.pacbrake.com/index.php?page=p67-loadleash
bmoeller
Postby PToombs » Tue Dec 25, 2012 10:06 am
That figures, spend time to design one for the truck that has a brake built in and screw the guys that have needed it for over 20 years. :roll:
Postby Mark Nixon » Tue Dec 25, 2012 2:42 pm
Are they driving the compressor off the INJECTION PUMP NUT? :shock:
Yikes, not sure I'd buy that until someone else tested it for a while.
Postby 1992gen1_fan » Wed Dec 26, 2012 8:50 pm
bmoeller wrote:PacBrake makes one for the 6.7L engines. :D
That one is supposedly near silent, though the sole purpose is what counts. I really like the sound of the one for the 6bt in the vid though :D Watch out! here comes a Peterbilt... Or a ... dodge? :D
1992gen1_fan
Postby bmoeller » Wed Dec 26, 2012 9:07 pm
Mark Nixon wrote:Are they driving the compressor off the INJECTION PUMP NUT? :shock:
That is what I was wondering.................... Sure looks like it.
It is quiet because of the variable geometry turbo. Put a standard turbo on there, it won't be quiet! :lol:
bmoeller
Postby 1992gen1_fan » Wed Dec 26, 2012 9:23 pm
Ahh... That makes sense. The VGT EX brake used at the same time would silence it down. If I install a compression brake on my '92 I'll keep the VGT wide open 8)
1992gen1_fan
Postby bmoeller » Wed Dec 26, 2012 10:51 pm
1992gen1_fan wrote:Ahh... That makes sense. The VGT EX brake used at the same time would silence it down. If I install a compression brake on my '92 I'll keep the VGT wide open 8)
Wouldn't even have to be using the exhaut brake function of the VGT, to quiet it down.
bmoeller
Postby 1992gen1_fan » Thu Dec 27, 2012 6:57 pm
If you open the VGT all the way, the exhaust not it loud. Maybe louder than the h1c. I think the compression brake would still sound loud with VGT open 8) . I could be wrong though. :)
1992gen1_fan
Postby cmann250 » Mon Dec 31, 2012 10:50 am
I wish they'd show what's going on under the valve covers. I assume oil is used to activate it, but it's not like there's an injector lobe on the cam to bump it off. Fly cut pistons? Jeremy showed me how one works at SOP, but I forget :roll:
Postby Mark Nixon » Mon Dec 31, 2012 11:39 am
Postby oldestof11 » Mon Dec 31, 2012 1:11 pm
That's a good read Mark!
Who is making these again ?
Postby Mark Nixon » Mon Dec 31, 2012 1:24 pm
Not sure who is making them for the Cummins 5.9.
I actually liked the YouTube link better, nothing like an aged video, concise information and an enthusiastic narrator to help learn something. 8)
