Sorry guys I didn't search the web for 10 hours for my problems. I'd rather tell you my semptoms. So if someone could point me in the right direction, I'd really aprecate it.
I bought a 91.5 w250 auto truck about two weeks ago. I've had it cut off on me a few times when I'm in the throttle and then let out of it. Then when I start it up a have to throttle it up and it has a ruff idle until I can get it going down the road. Finally it died on me Monday. I checked the fuel filter and it was full, so does that mean my lift pump is ok? Is it my injector pump? I did prime my lift pump a little before I checked the filter. At one time the lift pump didn't feel it was pumping, then after I purged am fuel filter it felt like it was pumping. Thanks for the advice in advance.
