Injection pump problem
Postby Jcs004 » Sat Jan 05, 2013 8:48 pm
I just finished resealing my IP pump myself bc it was leaking diesel. Everything was fairly easy except the head, when I took it off a couple of springs fell out. I'm pretty sure that I installed it back the right way, but when I put it back on the truck it started and revved up really high for a few seconds and stopped running. Now I only get fuel out of the number 2 injector line, any ideas on what I did wrong? I hope I didn't hurt it. Any help would be great, thanks!
Jcs004
Re: Injection pump problem
Postby directinjktn1stgen » Sun Jan 06, 2013 7:26 am
i would take back off and go back thru it be sure everything is how its suppose to be and i believe theres a stiky on the whole teardown of the pump that way u have like a guide. Dont feel bad mines leaking fuel right now as well fixin to tear it down
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Postby dazedandconfused » Sun Jan 06, 2013 8:30 am
I have the pdf file of the pump manual but I cant post it from my phone.
Postby PToombs » Sun Jan 06, 2013 5:41 pm
If fuel only comes out of 1 line, then something isn't turning inside. You may have snapped the shaft in it. I had one at work that only put fuel out of 1 line, and that had a bad shaft. His was caused by running veggie oil in 0* weather though.
Postby galakinokis » Tue Feb 19, 2013 2:44 pm
the head and rotor could have broke? the broken springs are common. but if you send in your pump to get rebuilt be prepared to have a backup core if the head is broken....500$ for just the head
galakinokis
