Best Mileage Injectors?
Postby 93DodgeCummins » Sun Jan 13, 2013 4:39 pm
I have been thinking about different injectors and i was wondering what injector size is the best for mileage?
Thanks
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: Best Mileage Injectors?
Postby PToombs » Sun Jan 13, 2013 5:59 pm
190's. More smaller holes give better atomization, promoting more power and better mileage over stock. They are actually smaller than IC injectors, but better on power.
Postby 93DodgeCummins » Sun Jan 13, 2013 6:29 pm
Do they flow more than stock injectors?
93DodgeCummins
Postby cougar » Mon Jan 14, 2013 10:18 am
You wouldn't think so, but with all my performance upgrades I've done to my 91 my fuel mileage remains unchanged.
Information on the 190s has been elusive. I would think they flow less being smaller, but makes up for it by being more efficient.
01 2500 "the work truck".
cougar
Postby 93DodgeCummins » Mon Jan 14, 2013 3:13 pm
What about something bigger? I heard going with something like 40hp injectors (dont know what hole size is) can help with mileage up to 2mpg or so.
93DodgeCummins
Postby PToombs » Mon Jan 14, 2013 6:02 pm
PToombs wrote: They are actually smaller than IC injectors, but better on power.
Postby RumbleFish » Mon Jan 14, 2013 7:32 pm
Postby kwrank » Mon Jan 14, 2013 8:36 pm
my experience with 190's has been a bit disappointing, but i can't entirely (yet anyhow) blame the injectors. they are hazy at idle and smoky down low, no matter how everything is adjusted--i wrote a post on this a while back and a couple others had the same issues. power and top end are better, and i have had a couple tanks of fuel that seemed to last forever, but for the most part no change in mpgs. i live at 6000', which doesn't help the haze, it gets better at lower elevations, but never really clears. i am going to jump a tooth soon, that seems to be the next logical step. i might add that the 190's really do not like winter fuel, even less than the stockers (what injector does?). i'm sure there are other issues involved, i just hope to get them ironed out before they water down the fuel even more.
92 W250 CC HX35/16 366 190's lp piston lift hughes converter
kwrank
Postby Alec » Sat Jan 19, 2013 2:39 pm
I have been curious about this, too, though changing injectors isn't at the top of my to-do list.
Am I correct in thinking that there are a good number of "190's" being sold that are not the same as the PDR injectors? And is there a post somewhere with information for identifying the "true" 190's?
The truck I bought from AZ has "performance" injectors that are supposed to be "190's". Decent performance, decent mileage, maybe, but mother of G, that truck smokes before it is warmed up. And forget about starting it in cold weather. I have a receipt from the shop that did it -- they charged the PO to "adjust the pump", but I sure hope they didn't advance the timing, 'cause that would just be grim . . .
Sorry for the interruption,
Alec
'91 W250: Getrag; 3.54's
Alec
Postby dazedandconfused » Sat Jan 19, 2013 3:05 pm
Injector pop pressure will cause hard starts and excessive smoke as well as incorrect spray pattern. Its hard to get info on the 190's other then they are 5 hole and smaller then ic sticks. I couldn't come up with much on a quick search.
Postby Remps » Sat Jan 19, 2013 4:18 pm
I have a set of 4 hole 190 injectors in a box somewhere. They were alright in a n/ic motor, but were hazy when cold in an ic motor.
Postby 93DodgeCummins » Sat Jan 19, 2013 11:45 pm
What about something slightly larger than the ic injectors?
93DodgeCummins
Postby D-dog357 » Sun Jan 20, 2013 10:04 am
I was wondering about the 7/10's that seem to be gaining in popularity ?
From what I've read they are a decent compromise of a bit more power/fuel with good atomization - less smoke and better mileage then most off the shelf nozzles.
That sounds good to me :D
From what I gather they are "built to order" so they come with the proper 145% spray angle and that's one of the reasons they have less smoke too.
Someone here has got to have some mileage on a set for a review - someone - anyone ???
'92 ex-cab, A/T, 3.56, timing bumped 1/4" , 366 w/ fuel 1/2 turn past collar, smoke all the way out and a ported HX hot side. Airbox and core support drilled for more cold air.
A no budget work truck.
D-dog357
Postby dazedandconfused » Sun Jan 20, 2013 10:07 am
I think Ellis may be running 7 holes.
Postby cougar » Sun Jan 20, 2013 10:56 am
I have a set. One of these days I'll get around to putting them in.
cougar
