Trouble finding engine brackets
Postby rcb » Mon Feb 18, 2013 3:06 pm
I am trying to find the motor mount brackets.
In the link below (hopefully It's ok to do this for reference) it'd be #1 in the diagram,
http://www.jeepdodgeoemparts.com/oem-pa ... ht/3894712
but of course for the Cummins. Does anyone have a part number they can reference? It seems like it shouldn't be that hard to find, but it's quickly getting to that point.
I've found a laundry list of numbers from different sites that all seem to be for gas engines, not diesel.
Any help is greatly appreciated.
Thanks!
rcb
Re: Trouble finding engine brackets
Postby turboram » Mon Feb 18, 2013 5:30 pm
Post in wanted section, someone should have a set they are willing to sell. I cant spare any right now, but if I find another set
turboram
Postby Mark Nixon » Mon Feb 18, 2013 7:48 pm
Not sure he CAN post in the "Wanted" section, he doesn't have 25 posts.
Some of us do have the parts he needs, though.
Postby odee » Mon Feb 25, 2013 5:26 am
do you still need these brackets? I may have a set off of a ninety model if they are the same.
odee
Postby turboram » Mon Feb 25, 2013 9:34 pm
Mark Nixon wrote:Not sure he CAN post in the "Wanted" section, he doesn't have 25 posts.
:roll: right duh
turboram
Postby rcb » Mon Mar 04, 2013 5:50 am
Odee
Yes I do still need them, if you have a set. I had just planned to try and buy new, as they didn't seem like they should be too expensive, but...
rcb
Postby BC847 » Mon Mar 04, 2013 8:05 am
PM should not be an issue for rcb now.
Postby odee » Mon Mar 04, 2013 8:23 pm
I will be out in the shop tommorow evening I'm picking up from putting the head back on my blue truck. I think I know where I put them.
odee
Postby rcb » Mon Mar 04, 2013 8:45 pm
Thanks, I greatly appreciate it.
rcb
Postby odee » Sun Mar 10, 2013 6:12 am
Want-Ads and ForSale stuff must go in our classifieds Section.
BC
odee
Postby rcb » Mon Mar 11, 2013 6:08 am
I can do that. I actually have the part that bolts to the block (kinda got taken on that set of engine mounts sadly).
My email is rc_brooks at yahoo.com
rcb
Postby thrashingcows » Mon Mar 11, 2013 5:51 pm
So if you have the parts that bolts to the engine, then all you need is the rubber isolators right? You can get the Anchor mounts at many parts houses.
thrashingcows
Postby rcb » Wed Mar 13, 2013 11:51 am
There is a metal bracket that bolts to the part that bolts to the engine. In the first link you can see essentially what the part is. It goes between the part that bolts to the block and the isolator. I think odee may have me taken care of.
rcb
Postby thrashingcows » Fri Mar 15, 2013 8:09 pm
I didn't notice that the pic you posted was for a V8..not a cummins. So you need the metal plates that bolt to the engine.
thrashingcows
