Vacuum leak help?
Vacuum leak help?
Postby slow_90firebird » Sun Mar 17, 2013 5:21 pm
Hey guys been away for a while but hope someone can give me some advice...
Symptoms:
Brake pedal gets hard after more than 1 pump
Brake and Abs lights on after 2 pumps
4 or 5 pumps and the lights stay on for 20-30 sec at idle
Lights go out faster if I revv engine
Also, starting the same day, I noticed after I shut off the truck with the hvac set on floor heat, the vac actuator that moves the flap by my feet returns back to the defrost position. If I restart the truck the heat comes out the defroster momentarily before transitioning back towards my feet...
I'm not sure if it always did that. But the little flap door inside the heater never made noise before...
How should I start looking for vac leaks? I can't spray carb clean like a gasser...
Thanks!
slow_90firebird
Re: Vacuum leak help?
Postby Mark Nixon » Sun Mar 17, 2013 8:03 pm
What year?
Sounds like the vacuum pump might be on it's way out.
Get a gauge and see if it has more than 15 inches of vacuum.
Postby slow_90firebird » Sun Mar 17, 2013 8:32 pm
1993 auto 4x4. I didn't realize these vac pumps could go bad... I just had it halfway apart for the o-ring and seal kit installation a few months ago.
So 15" is the magic #? Il check tomorrow.
Assuming the pump is still working, could I use the evap smoke machine to pressurize the vacuum lines with smoke? Or are there 1-way valves that would prevent the smoke pressure from getting around?
slow_90firebird
Postby slow_90firebird » Mon Mar 18, 2013 11:13 am
Found the leak!
Thanks! I can't believe that's all it was. When I tested the vac pump though it put out 29-30" so I'm guessing that's good...
Only downside was I broke the plastic barb off the vac sensor... Now I gotta find a way to fix that
slow_90firebird
Postby Mark Nixon » Mon Mar 18, 2013 11:22 am
It's the simplest, dumbest stuff that'll make you pull your hair out.
Glad it was actually easy to find!
BTW, that's basically EXCELLENT vacuum at ~29".
Postby slow_90firebird » Mon Mar 18, 2013 1:04 pm
Ya I know and the worst part was that I looked at everything else first... Finally I pulled the check valve out of the booster and saw that right away!
I was just worried because this morning I had essentially no power brakes at all and tonight were supposed to get a snow storm. Didn't wanna drive to work tomorrow like that and my car hates the snow...
slow_90firebird
