Hey guys been away for a while but hope someone can give me some advice...
Symptoms:
Brake pedal gets hard after more than 1 pump
Brake and Abs lights on after 2 pumps
4 or 5 pumps and the lights stay on for 20-30 sec at idle
Lights go out faster if I revv engine
Also, starting the same day, I noticed after I shut off the truck with the hvac set on floor heat, the vac actuator that moves the flap by my feet returns back to the defrost position. If I restart the truck the heat comes out the defroster momentarily before transitioning back towards my feet...
I'm not sure if it always did that. But the little flap door inside the heater never made noise before...
How should I start looking for vac leaks? I can't spray carb clean like a gasser...
Thanks!
