Popping radiators
Popping radiators
Postby mhuppertz » Sun Mar 24, 2013 3:37 pm
I thought my truck was eating radiators because of the head gasket leak, but I just hauled a 1969 Camaro and my 1956 Plymouth from 4,500ft to 7,000 and I blew another one! Maybe I need to run lower pressure caps or something...
mhuppertz
Re: Popping radiators
Postby cmann250 » Sun Mar 24, 2013 3:52 pm
I'm wanting to say the stock cap is 15 or 16 pounds.
I'd not be supprised if replacement radiators are not as good as OE like alot of stuff is becoming.
Postby Mark Nixon » Sun Mar 24, 2013 8:01 pm
Never popped an OEM or replacement radiator on a Cummins truck ever.
Gotta' be other issues.
Postby Hansen01 » Mon Mar 25, 2013 8:46 am
When my head gasket was out it way over pressured my radiator, so maybe put a pressure tester on it just to be sure
And yes the stock caps are 15 or 16
Under construction...
Hansen01
Postby mhuppertz » Mon Mar 25, 2013 12:53 pm
It might just be bad luck. I will pull the fan when I get a chance and see what the damaged part looks like.
mhuppertz
Postby dazedandconfused » Mon Mar 25, 2013 12:56 pm
When you have popped them have you noticed what your temps were?
Postby mhuppertz » Mon Mar 25, 2013 2:30 pm
dazedandconfused wrote:When you have popped them have you noticed what your temps were?
Normal.
mhuppertz
Postby bmoeller » Tue Mar 26, 2013 9:00 pm
You have a new head, too? Correct?
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby PToombs » Wed Mar 27, 2013 4:52 pm
Did you change the thermostat when you did the head? If so, what brand did you put in?
Postby mhuppertz » Wed Mar 27, 2013 7:40 pm
PToombs wrote:Did you change the thermostat when you did the head? If so, what brand did you put in?
No, and Stant I think.
mhuppertz
Postby Mark Nixon » Wed Mar 27, 2013 7:47 pm
Junk.
Go buy one from Cummins.
Postby ellis93 » Wed Mar 27, 2013 7:48 pm
Mark Nixon wrote:Junk.
X2 btdt
Postby mhuppertz » Wed Mar 27, 2013 7:56 pm
Thanks for the advice guys. I will pick one up tomorrow.
mhuppertz
Postby PToombs » Thu Mar 28, 2013 5:43 pm
One from a Case dealer is equivelant, that's where mine came from. Aftermarket ones just suck for some reason.
Postby apexfd » Sat Jun 01, 2013 9:15 pm
Does anyone know a good source for an all aluminum radiator that would fit a NON IC truck?
apexfd
