Truck doesnt die right off after injector pump rebuild
Postby Dodgebob1980 » Tue Apr 02, 2013 6:53 pm
Ok i had my pump rebuilt at a local shop. The guy that did it has been doing it for ever. It was doing great but after about a hundred miles it doesnt die right off now. Any ideas? If it is pump internal ill just take it to him. Hopefully i wont have to pull it back off.
Dodgebob1980
Re: Truck doesnt die right off after injector pump rebuild
Postby ellis93 » Tue Apr 02, 2013 6:57 pm
Could be a weak fss plunger spring,or missing
Postby Dodgebob1980 » Tue Apr 02, 2013 7:00 pm
ok thank you
Dodgebob1980
Postby ellis93 » Tue Apr 02, 2013 7:03 pm
Dodgebob1980 wrote:ok thank you
That's a big maybe ;)
Postby Dodgebob1980 » Tue Apr 02, 2013 7:06 pm
still runs good but he garanteed for a year probly just take it to him let him decide
Dodgebob1980
Postby RCCUMMINS89 » Tue Apr 02, 2013 7:21 pm
If it isn't shutting off, then it's probably the FSS plunger..... but I've in the past had an issue with a vehicle that it took a few seconds to shut off.... turned out to be a bad ground. Grounds do goofy stuff..
Postby Dodgebob1980 » Tue Apr 02, 2013 7:27 pm
It dies slowly like its winding down, a second or less after key shut off, my other 12v just dies. this one was working great, still runs the same just dies slow, no pause just slows down til it dies
Dodgebob1980
Postby BC847 » Tue Apr 02, 2013 7:33 pm
I think your FSS plunger rubber is torn.
You may/should be able to mill it down and salvage it while making it more reliable.
Postby Dodgebob1980 » Tue Apr 02, 2013 7:39 pm
I hope its that easy i dont want to pull pump if i dont have to. Just for thought what if the fss was loose, just backed out a bit maybe?
Dodgebob1980
Postby BC847 » Tue Apr 02, 2013 7:43 pm
Dodgebob1980 wrote: Just for thought what if the fss was loose, just backed out a bit maybe?
If the FSS was loose, you'd most likely have a very obvious fuel leak. (They're usually a PITA to loosen).
Postby Dodgebob1980 » Tue Apr 02, 2013 7:48 pm
ok, Thanks for the imput, ill look tomorrow maybe when the sun is out. Just started doing this tonight.
Dodgebob1980
Postby bill-d-c » Wed Apr 03, 2013 6:39 pm
Does it take a special tool to pull the FSS? And, do you have to bleed the system after replacing one?
Bill
bill-d-c
Postby Dodgebob1980 » Wed Apr 03, 2013 6:45 pm
Not sure looks like a regular wrench will work but a real bear to get to. the guy that rebuilt it said it wont hurt anything so ill probably just put a cable on the manual shutdown. Easy fix.
Dodgebob1980
Postby RCCUMMINS89 » Wed Apr 03, 2013 6:51 pm
No special tools, no bleeding of the system. Just almost impossible to get to.
Only thing that can happen is if the fss plunger rips off they can get lodged in the delivery valves and eventually into the injector body. You'll know because you won't have any power.....
Postby PToombs » Thu Apr 04, 2013 4:24 pm
Take a crescent wrench and break off the top of the flat bracket on the end of the pump. Partially cutting it with a hacksaw or grinder will help. Since it was just rebuilt the FSS should come out fairly easily. Use a 15/16 wrench and rip it outta there! It's not that big of a job really. ;)
