what in the world is this growling I hear in my 92
Postby hager » Thu Apr 18, 2013 8:22 pm
what in the world is this growling I hear in my 92 Cummins
its like metal churning it is obnoxiously loud :?:
THING I HAVE DONE
check the dowel pin}
found fuel leaking out of my Ve pump so I had it rebuilt
new injectors
took head off to check pistons look great .
checked main and connecting rod bearing they seem fine I'm going to replace them
can you think of anything else,?
please!! help
hager
Re: what in the world is this growling I hear in my 92
Postby TRACTJDS0428 » Fri Apr 19, 2013 3:36 pm
have you narrowed it down to the engine? on my '93 a bearing in the over drive housing went out an took the cage and everything and ground it up. started out sounding like i have a set of super swamper boggers on the truck then got louder and louder till it sounded like the trany was grinding up steel. just a thought. i also had the trany lines vibrating and the lead me to think it was a worse problems than it was.
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Postby dazedandconfused » Fri Apr 19, 2013 3:48 pm
Welcome to the site. It would help if you gave specs on the truck transmission, 4x4 or 2x4, what rpm it happens at etc.
Postby hager » Fri Apr 19, 2013 6:10 pm
I assumed it wasn't my transmission its been rebuilt about 20,000 miles to go
actually I just tightening torque converter bolts some "Jack wagon "strip one out but I don't think it was rubbing against the engine but come to think of it I didn't narrow it down to the engine
what's got me stumped is my pump was leaking really bad that's why I took the course I did
I'd really hate to put this thing back together and miss something .
of course while it out I want to do rings and bearings head studs new head gasketyou know just to freshen up
hager
Postby hager » Fri Apr 19, 2013 6:18 pm
[quote]. It would help if you gave specs on the truck transmission, 4x4 or 2x4, what rpm it happens at etc.[quote]
well its a 92 Dodge 1 ton dually four wheel drive A518 trany cummins nothin done to it its bone stock except for a
tps delete.and a Don Williams 8) tape in the player
hager
Postby dazedandconfused » Fri Apr 19, 2013 6:22 pm
I would be looking at the transmission myself especially since a converter bolt was stripped.
Postby hager » Fri Apr 19, 2013 6:26 pm
I was going down the road at about 60 mph and it happened all at once
it was loud.
hager
Postby dazedandconfused » Fri Apr 19, 2013 6:27 pm
Was the bolt missing that was stripped?
Postby hager » Fri Apr 19, 2013 6:49 pm
it was just stripped out it wasn't to lose
how did you end up fixing yours?
hager
Postby hager » Fri Apr 19, 2013 6:50 pm
oh yeah and the bolt was there
hager
Postby dazedandconfused » Fri Apr 19, 2013 6:57 pm
I've not had that issue but since you found torque converter bolts loose and stripped what do you think they slacked on in the rebuild would be what I was wondering. Now if you did it yourself it kills part of that theory. Also have you checked transfer case fluid to make sure it hasn't been ran dry
Postby Tacoclaw » Fri Apr 19, 2013 6:58 pm
So, does it only do it while moving? While moving forward? While moving backward? While in 4x4? While in 2x4? With the stereo tuned to 101.5?
Gotta get a lot more specific, man, there's just too much potential stuff for it to be. The better description you can give of the symptoms, the closer our remote guessing is going to be.
Postby hager » Fri Apr 19, 2013 8:21 pm
so it only makes a noise when the motor is running its so bad of a noise that the first thing I checked was the dowel pin coming out to my surprise it was fine so I tabbed it it doesn't seem to be related to transmission although I haven't ruled it out its a real metal metallic sound growling coming from sounds like one of the cylinders but I've already ruled that out because the cylinders look fine I'm down to the head .my brother thinks it could be in my power steering pump but it works fine
could it be possibly my turbo?
the turbo spins freely because I spend it with my finger no bad sounds but does that rule out a bad turboand I didn't get to drive enough to know if the turbo went bad power wise
hager
Postby hager » Fri Apr 19, 2013 8:27 pm
Dazed
I didn't do the rebuild myself I bought this truck with the rebuild and talk to the shop who did it seem to be legitimate guys its a factory and he told me the specs don't seem to have a problem other than this bolt which it could have been this bold but I will never know until I put the engine back together and I don't want to put together and find out that it wasn't
hager
Postby Tacoclaw » Sat Apr 20, 2013 4:39 am
Well, if the truck doesn't have to be in motion that does narrow it down a bit. :grin: It could still be in the trans but it's nothing on the output side or the transfer case.
