Bus VE pump
Bus VE pump
Postby Ram360man » Fri Apr 19, 2013 11:51 am
Injection pump has started making more racket and has metal in the return banjo filter. Its going in for a rebuild. I have a good ve off of a school bus. Bosch tech said he wasn't sure if it would work. Ran the numbers and he said the head/rotor are differant and the cam plate is a differant model from the non i/c pump. Was off a 180hp 5.9. Was thinking of just running this instead for now. Shouldn't run into any issues with it should I? Its also a non KSB pump.
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: Bus VE pump
Postby SuperiorRam » Fri Apr 19, 2013 12:07 pm
I liked mine till it blew apart
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Re: Bus VE pump
Postby bgilbert » Fri Apr 19, 2013 1:23 pm
I'd run it and wouldn't worry about it. You should be fine.
Bill Gilbert
bgilbert
Re: Bus VE pump
Postby PToombs » Fri Apr 19, 2013 4:18 pm
X3, it may run better than the one you take off.
Re: Bus VE pump
Postby Ram360man » Fri Apr 19, 2013 6:57 pm
What I kind of figured. Think I should replace the return springs with the high rpm ones? Pretty sure thats what let loose in the current pump.
Ram360man
Re: Bus VE pump
Postby SuperiorRam » Mon Jun 03, 2013 6:40 pm
I think that's what let go in my "180" pump I'd change em...
SuperiorRam
Re: Bus VE pump
Postby Mark Nixon » Mon Jun 03, 2013 7:40 pm
So, my Brand New 192 horse pump should have the springs changed, first? :P
Re: Bus VE pump
Postby SuperiorRam » Tue Jun 04, 2013 3:47 am
Brand new 192 pump= apples
An Old school bus pump the has been on and off the throttle = oranges
In my humble opinion
SuperiorRam
Re: Bus VE pump
Postby Mark Nixon » Tue Jun 04, 2013 6:44 am
SuperiorRam wrote:Brand new 192 pump= apples
Well, I prefer oranges, as a food. ;)
But if a new pump of any pedigree means apples, then Washington Reds it'll be. :lol:
Re: Bus VE pump
Postby Sidebottom » Mon Jun 10, 2013 7:18 pm
might be the first gen's Hot rod pump lol
Sidebottom
