engine
engine
Postby hager » Mon Apr 29, 2013 6:49 pm
should I go genuine cummins on my engine rebuild??
hager
Re: engine
Postby RCCUMMINS89 » Mon Apr 29, 2013 7:45 pm
I've been told by an extremely reliable builder that recently there are other companies that are WAY better than Cummins has "sunk" to.
I'll try and get the name of the company he uses.
Re: engine
Postby ellis93 » Mon Apr 29, 2013 8:23 pm
Clevite bearings,felpro everywhere but headgasket. For that I've been told Cummins marine gasket,I don't know the reasoning behind that tho......could be that there is some mystical voodoo in it :lol:
Re: engine
Postby 4thesporty » Mon Apr 29, 2013 8:44 pm
no such thing as a cummins marine head gasket, just a 6BT head gasket.
1994 Chevy K3500 12V/NV4500
Full rebuild with mahle non I/C pistons, 370s (set @ 250 bar), HX35/HT3B, custom cam, studs and orings. Yep, it's a VE :)
Still in progress
4thesporty
Re: engine
Postby ellis93 » Tue Apr 30, 2013 3:32 am
4thesporty wrote:no such thing as a cummins marine head gasket, just a 6BT head gasket.
Ok thanks for the correction,must be a lot of wrong people out there
Re: engine
Postby dazedandconfused » Tue Apr 30, 2013 3:45 am
According to Cummins there is. I was just talking to local Cummins dealer about this.
Re: engine
Postby BC847 » Tue Apr 30, 2013 4:07 am
Part numbers?
Re: engine
Postby dazedandconfused » Tue Apr 30, 2013 5:17 am
I didn't get the part numbers I called for pricing. First question he asked was marine or standard engine since the marine engine runs a slightly different head gasket.
Re: engine
Postby ellis93 » Tue Apr 30, 2013 6:20 am
Found (thru a google search) these part numbers for different thicknesses from Cummins.....
12V head gaskets 3283335 STD 3283337 010 3283339 020.
From what I've read the thicker headgaskets was used on the marine applications
Re: engine
Postby 4thesporty » Tue Apr 30, 2013 7:04 am
some marine engines run a thicker headgasket stock to slighty lower compression. Many refer to a 20 over cummins headgasket to a marine head gasket for some reason. A 5.9 12V long block is the same internally (with some minor variations) across the board up until the STORM block.
Still in progress
4thesporty
Re: engine
Postby RCCUMMINS89 » Tue Apr 30, 2013 7:35 am
Cummins Northwest wanted me to buy a .10 over when I did my headgasket. So, yes they make diff. thicknesses.
I know the gentleman who would be building my short block. Uses a different aftermarket piston that has a "better heat sink design" with a thicker bowl ridge and lowers compression from 17.9 to 17.5.....then run a standard thickness gasket. He said that nets better h/g reliability when one is using o rings (better bite) and yet still produces the same end result as a thicker gasket but with a better design piston that won't melt quite so fast.
Re: engine
Postby hager » Tue Apr 30, 2013 7:13 pm
http://www.northernautoparts.com
after doing some research and putting together what you guys told me I ended up
Ordering above is the website that I used to order all my parts its more like a refreshing up kit they offer its arb head studs in all seals rings main bearings connecting rod bearing I think it cost me $875.00 shipping and all
I appreciate your help men
hager
Re: engine
Postby hager » Tue Apr 30, 2013 7:16 pm
the man was real nice his name is Steven he said they would all be in by Thursday looks like I gotta pack weekend :) cant wait
hager
Re: engine
Postby Diesel Dawg » Wed May 01, 2013 11:43 am
hager did you find what was making noise in your engine?
Diesel Dawg
Re: engine
Postby hager » Wed May 01, 2013 11:58 am
No haven't had a lot of time to work on itI want to tear into a little more tomorrow and the weekend
hager
