by cummins32 » Thu May 09, 2013 3:41 pm
I installed a hx35 a few months ago, and my truck just doesn't have the bottom end like it used to, I've adjusted the starwheel, up to get it to spool faster, but it hasn't changed, It'll build about 35lbs and can it about 1550 on the egts, Just a few hundred degrees to hot for my likings
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
