Trying to understand...
Postby 93 W350 LE » Mon May 27, 2013 7:03 am
Ok, so if I am startng to understand the way fueling works, the lift pump is the fuel pump that brings the fuel from the tank to the injector pump, that essentially controlls both the volume of fuel deliveted and the timing of the fuel to the injectors. So making the compare to gas, the lift pump is your fuel pump, and the IP is a combination of carberator/ignition distributor. Tweaks to the fuel pin and star are like needles and jets and and advancing the IP is similar to ignition timing, by delivering fuel earlier in the combustion stroke. Now does this allow more volume of fuel or the same amount, just sooner?
Sorry guys, just trying to understand. Kind of like English to Spanish, but just want to understand what I am doing not just do it.
Thanks,
Eric
93 W350 LE
Re: Trying to understand...
Postby BC847 » Mon May 27, 2013 8:58 am
- The lift-pump simply brings the fuel to the IP. That is all. The IP is actually capable of drawing its fuel directly from the tank in certain instances. It has no bearing on what the IP does with the fuel.
- The AFC stuff including the smoke-screw, fuel-pin, star-wheel, ect, impact the fuel-air ratio in part-throttle conditions.
- Rotating the IP itself (relative to the crankshaft) effects the injection event timing. The VE IP is unique in that it has a dynamic injection event timing device. It acts much like the springs and weights in the typical old-school ignition distributor.
- Delivery of the fuel is accomplished via the Head/Rotor:
- The quantity of fuel delivered is controlled by the control collar (part no 5 above).
Postby 93 W350 LE » Tue May 28, 2013 4:08 pm
Isn't part #5 the star nut? To effect more fuel throughout, do you adjust the full load screw, or is that just for flow at WOT?
Eric
93 W350 LE
Postby PToombs » Tue May 28, 2013 4:27 pm
Yes it is! The full load screw is usually called the fuel screw. It increases fueling thru the whole band.
Postby skilletky » Wed May 29, 2013 7:18 am
93 W350 LE wrote:Isn't part #5 the star nut? To effect more fuel throughout, do you adjust the full load screw, or is that just for flow at WOT?
Eric
he is talking about part #5 in the fuel delivery phase chart. not the 1st pic in the post
skilletky
Postby 93 W350 LE » Wed May 29, 2013 8:52 am
Ok. Thanks on that clarification. Makes a little more sence nw.
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
