Ok, so if I am startng to understand the way fueling works, the lift pump is the fuel pump that brings the fuel from the tank to the injector pump, that essentially controlls both the volume of fuel deliveted and the timing of the fuel to the injectors. So making the compare to gas, the lift pump is your fuel pump, and the IP is a combination of carberator/ignition distributor. Tweaks to the fuel pin and star are like needles and jets and and advancing the IP is similar to ignition timing, by delivering fuel earlier in the combustion stroke. Now does this allow more volume of fuel or the same amount, just sooner?
Sorry guys, just trying to understand. Kind of like English to Spanish, but just want to understand what I am doing not just do it.
Thanks,
Eric
