IC plumbing?'s
IC plumbing?'s
Postby 93 W350 LE » Sat Jun 01, 2013 12:47 pm
If I replace the stock tubes from the turbo into the IC and out of the IC with 3" will this help with cooling, or is the IC gonna be a choke point? Could there be pressure issues in the IC, causing damage? I ask because I came across some 3" tubes from a diesel poweres aircompressor, and they are begging to be used.lol.
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: IC plumbing?'s
Postby apexfd » Sat Jun 01, 2013 8:50 pm
I doubt it would help much unless your existing piping is restricting flow. Ie if you are making lots of power
apexfd
Re: IC plumbing?'s
Postby 93 W350 LE » Sun Jun 02, 2013 5:07 am
Just looking for anything I can do to help keep egt's and all other temps down while hauling my 14k lb 5th wheel.
Thanks
Eric
93 W350 LE
Re: IC plumbing?'s
Postby ellis93 » Sun Jun 02, 2013 8:36 am
apexfd wrote:I doubt it would help much unless your existing piping is restricting flow. Ie if you are making lots of power
It'll help,egts will go down by at least 50°,least they did with the coolertubz. Engine also seemed to respond well to them by reving quicker,seemed is the operative word here. Biggest thing is to be rid of the stock air horn,everything till that piece leaves is secondary.
Re: IC plumbing?'s
Postby Philip » Sun Jun 02, 2013 12:43 pm
What he said.
Re: IC plumbing?'s
Postby 93 W350 LE » Sun Jun 02, 2013 5:07 pm
Cool. S to free things up I need to replace the restrictive stock air horn.
Thanks.
Eric
93 W350 LE
Re: IC plumbing?'s
Postby 93 W350 LE » Mon Jun 03, 2013 11:01 am
Would insulating the tube from the fresh air to the turbo and from the IC to the air horn help anything?
Eric
93 W350 LE
Re: IC plumbing?'s
Postby Philip » Mon Jun 03, 2013 2:44 pm
93 W350 LE wrote:Would insulating the tube from the fresh air to the turbo and from the IC to the air horn help anything?
Eric
No not that I have heard of. The object is to remove heat from being compressed by the turbo. Insulating the pipes would defeat that purpose.
