by 93 W350 LE » Sat Jun 01, 2013 12:47 pm
If I replace the stock tubes from the turbo into the IC and out of the IC with 3" will this help with cooling, or is the IC gonna be a choke point? Could there be pressure issues in the IC, causing damage? I ask because I came across some 3" tubes from a diesel poweres aircompressor, and they are begging to be used.lol.
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
