Jake brake
Jake brake
Postby 92cummins89 » Fri Sep 27, 2013 1:53 pm
Was wondering if anyone put a jake break on there first gen
How does it sound
do u like it
92cummins89
Re: Jake brake
Postby cmann250 » Fri Sep 27, 2013 5:39 pm
They don't make a Jake brake for the B series. Yet. One company has a prototype that they're testing. It sounds sweet. It is completely functional too which is awesome since our brakes are so bad.
Re: Jake brake
Postby brandonmgreer » Fri Sep 27, 2013 10:15 pm
Where can I get info on this? A REAL Jake brake? Like it goes in the rocker boxes... hehehe I'm excited about this! Then I can have Jakes on my daily driver and my pickup! :bom:
brandonmgreer
Re: Jake brake
Postby cmann250 » Sat Sep 28, 2013 4:35 am
Re: Jake brake
Postby Diesel » Sat Sep 28, 2013 8:27 am
cmann250 wrote:http://www.youtube.com/watch?v=WncV8Hl3e_I
Is it just me or is that compression release company stuff really weak? I wanted a couple videos and other than a bunch of noise it didn't seem to slow down an unloaded truck much or like a jake does.
1991.5 D250 Intercooled A518
Diesel
Re: Jake brake
Postby RCCUMMINS89 » Sat Sep 28, 2013 8:38 am
Nothing wrong with a good ol' exhaust brake. My buddy has a one on his p pumped 1 st gen. And with that thing will throw you through the window.
Re: Jake brake
Postby cmann250 » Sat Sep 28, 2013 9:26 am
Diesel wrote:Is it just me or is that compression release company stuff really weak? I wanted a couple videos and other than a bunch of noise it didn't seem to slow down an unloaded truck much or like a jake does.
I have a feeling that you could tune them "beyond the manufacturer's recommendations" to get a little better performance. It looks like they're driving the system off of the IP nut, which is kind of scary.
Re: Jake brake
Postby 92cummins89 » Wed Oct 09, 2013 5:19 pm
RCCUMMINS89 wrote:Nothing wrong with a good ol' exhaust brake. My buddy has a one on his p pumped 1 st gen. And with that thing will throw you through the window.
Where did he get it from
92cummins89
Re: Jake brake
Postby RCCUMMINS89 » Wed Oct 09, 2013 6:16 pm
We (he) put a BD exhaust brake on his truck.
BD makes a 1st gen specific brake..... PM me if you are interested in one.
Re: Jake brake
Postby 1992gen1_fan » Wed Oct 16, 2013 4:49 pm
I think the setup with the deal attached the the IP nut was an earlier prototype. I think they've changed it since then but not for sure. On one of their newer videos the setup looked like it was belt driven. I'm still skeptical of the whole operation because of the lack of info. But I guess they're still waiting on patent stuff. :?:
1992gen1_fan
