Engine storage
Engine storage
Postby DodgeFreak » Thu Dec 19, 2013 12:38 pm
Best way to store an engine for a few years??? fill the cylinders with oil?? any other tips. Truck runs as of now.
Re: Engine storage
Postby simplysmn » Thu Dec 26, 2013 8:38 pm
Is The Motor going to be out of truck ? if so cover exhaust port on turbo and Intake and then cover the intake side of Motor you will be fine . I pulled my donor apart and just taped everything shut it was 2 yr's before it got set back into place just uncovered everything and fired it up . No problem's
simplysmn
Re: Engine storage
Postby the.beard » Thu Dec 26, 2013 11:42 pm
If you're storing the whole truck, consider pest control. Every Chrysler I've ever seen sit up for any amount of time was a rodent magnet.
1991.5 W250 Standard Cab, Long Bed. BONE STOCK (except for the dents; installed those myself)
"America is all about speed. Hot, nasty, badass speed." ~Eleanor Roosevelt
the.beard
Re: Engine storage
Postby CumminsPower59 » Fri Dec 27, 2013 9:27 am
Doesn't matter what it is, rodents get into everything.
Re: Engine storage
Postby JimmieD » Fri Dec 27, 2013 11:04 pm
Lots of companies make ultrasonic rodent repeller devices. They plug into 110V and draw almost nothing for power, if you'll have electricity available. They work, I use them in a travel trailer.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Re: Engine storage
Postby PToombs » Sat Dec 28, 2013 4:29 pm
Moth balls or dryer sheets work good too. Don't get the environmentally friendly dryer sheets, they are so friendly the mice use them for their nests. ;)
Re: Engine storage
Postby DodgeFreak » Sat Dec 28, 2013 6:34 pm
Lol thanks for the tips....but ill be pulling the engine out and scrapping the rest i dont use.
Re: Engine storage
Postby the.beard » Tue Dec 31, 2013 8:19 pm
DodgeFreak wrote:Lol thanks for the tips....but ill be pulling the engine out and scrapping the rest i dont use.
Aw, that's a shame. In that case, I'd just make sure there's no tap water in the block and use balled up plastic bags instead of wadded up rags to plug holes.
the.beard
