Leaky injectors ?
Leaky injectors ?
Postby jmos4 » Thu Jan 02, 2014 10:50 am
Hi
I've got a 89 d250 with a little over 200,000 on it is it common for the injectors to leak?
Is it just a matter of replacing o-rings to fix?
Regards,
Jim
1992 Dodge 250 4 x 4
currently 360 TBI
NV4500, NP241
Dana 60's 4.10 gears
soon to be Cummins powered
1989 D250
Cummins NV4500 (Donor)
jmos4
Re: Leaky injectors ?
Postby theoldmanW350 » Thu Jan 02, 2014 11:34 am
I'm a newbie but what I understand is a leaking injector is an internal issue. Getting them pop tested will determine if they need to be serviced or traded in for a new set. Some guys here built their own tester out of a bottle jack and a pressure gauge and some brass fittings. Pop tests are not cheap and you may get advice to simply buy a new set. Can't go wrong really. I believe our 9mm tip injectors are favorable to guys pushing big HP. You could probably sell them.
1990 W350. Getrag overfilled. Stock fuel. Stock turbo. M2 fuel pin. Hungry Diesel HVLP lift pump, 2nd gen IC w/ 3" Pusher Intake. Air bag set-up, onboard air. BD exhaust brake. Almost all 4" exhaust. Autometer's. Upgrades as money allows.
theoldmanW350
Postby RCCUMMINS89 » Thu Jan 02, 2014 12:02 pm
Where are they leaking from?
Postby jmos4 » Fri Jan 03, 2014 8:48 am
Its a external leak head is wet with fuel, runs fine no smoke so I don't believe there is are internal leaks
Jim
currently 360 TBI
NV4500, NP241
1989 D250
jmos4
Postby RCCUMMINS89 » Fri Jan 03, 2014 9:02 am
Tighten down your injector locknuts and see if it goes away. Most likely, they have loosened up or the coppers have shrunk over the years.
Postby theoldmanW350 » Fri Jan 03, 2014 4:40 pm
Ha. A perfect example for me to Keep it Simple Stupid!
theoldmanW350
Postby jmos4 » Thu Jan 09, 2014 10:09 am
I'll have to try it this weekend as too dam cold out (- temps) what size are the hold downs as I think I will need a crowsfoot to get to them as attempted with a wrench and really couldn't get on them very well
when tightening them do I need to loose the return lines or injector connections?
Thanks
Jim
currently 360 TBI
NV4500, NP241
1989 D250
jmos4
Postby CumminsPower59 » Thu Jan 09, 2014 11:03 am
You'll have to pull the line off the injectors to get a good bite on the hold down nut. Factory spec is 44lb-ft, but I have gone a bit past that to keep them from bubbling...like 50-55lb-ft.
Postby RCCUMMINS89 » Thu Jan 09, 2014 11:14 am
Yep... pull a valve cover or two and you can swing the injection line out of the way easier. DON'T OVERTIGHTEN the valve cover bolts either, they will leak.
Postby PToombs » Thu Jan 09, 2014 6:13 pm
You can pull the injector and return lines and torque it with a deep socket, or just snug it a little with a wrench. If you have more than 1 or 2 leaking, I'd say torque them all.
