How much more whistle?
Postby bmw4aaron » Tue Jan 14, 2014 6:51 pm
The good ol snowball effect. What started out as just checking my air filter tuned into a BHAF, bracket (can't remember the name but plans are online), turbo rebuild and GDS 60mm wheel/housing. I'm LOVING the whistle but can more (louder) be had? I'm still running the big stock rubber boot from air filter to turbo. I've read as well as advised in another post here to change it over to a metal pipe. Just how much more whistle will this net me? Enough to justify another $70 or so in parts?
BMW runs a pipe into the cabin from the air box to make the engine sound loud under spirited driving. I'm tempted to do this so my ears will bleed while spooling.
bmw4aaron
Re: How much more whistle?
Postby TheSilverBullet » Tue Jan 14, 2014 7:33 pm
Do what? Why ?
Brownie-1990 w250 straight six standard transmission 445k odometer quit in 02 lol
The Silver Bullet-1998 qcsb 12v twins and a 6 speed
Blue bear- 2001 3500 pee pumped 24
TheSilverBullet
Postby bmw4aaron » Tue Jan 14, 2014 7:48 pm
TheSilverBullet wrote:
Do what? Why ?
Which part?
bmw4aaron
Postby ellis93 » Tue Jan 14, 2014 7:49 pm
Do what? Why ?
:lol: things that make you go :scratch: :lol:
My hybrid turbo makes enough noise for me......I hardly turn on the radio anymore :lol:
Postby TheSilverBullet » Tue Jan 14, 2014 8:16 pm
Do what? Why ?
Which part?
The part about running a pipe inside the cab :scratch:
TheSilverBullet
Postby cmann250 » Tue Jan 14, 2014 8:25 pm
Having a metal pipe in the intake will make the turbo louder. My HX rivals an E model 3406 and that's about the top of the tolerable scale.
Postby Bschwarzli » Tue Jan 14, 2014 9:00 pm
Say what!? LMAO
If I did that on my truck, I would implode the windows or would run out of oxygen!
When I had the HX35 with factory intake, silencer ring MIA, it was decent. But then I added the ASA intake, then I called the truck the angry vacuum.
And now with thew Super HX40....lets just say I left the silencer ring in. At 35 PSI plus on the hills while towing, it was a wee bit too loud now!
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Postby bmw4aaron » Wed Jan 15, 2014 5:48 am
Do what? Why ?
Which part?
I definately wasn't being seroius!
bmw4aaron
Postby Tacoclaw » Wed Jan 15, 2014 7:27 am
Since it's not on the pressure side, you can get away with some cheaper couplers. No need for $30 silicone pieces.
http://store.airflo.com/45hl4.html
Or, any rubber 4" 45* will work if you can find them at a hardware store for plumbing or whatnot. Just make sure they're not made out of paper or something, they do have a small amount of vacuum to contend with. Just a normal piece of 4" exhaust pipe will do too, no need for anything fancy unless you want it.
A metal pipe will definitely make it louder.
Heres a pic of my old setup with those Airflo couplers and normal exhaust pipe. Worked and sounded great.
I later upgraded to an AFE ProDry air filter that was the same size as the BHAF, flowed and sounded even better than the BHAF, but if you're balking at buying $70 in couplers/piping I doubt you want to buy another $70 filter. :lol:
Postby bmw4aaron » Tue Jan 21, 2014 8:02 pm
Tacoclaw wrote:I later upgraded to an AFE ProDry air filter that was the same size as the BHAF, flowed and sounded even better than the BHAF, but if you're balking at buying $70 in couplers/piping I doubt you want to buy another $70 filter. :lol:
Alright I broke down and ordered the parts.
bmw4aaron
Postby BILTIT » Tue Jan 21, 2014 10:06 pm
Taco-what filter housing is that with holes in it?
Derek B.
BILTIT
Postby RCCUMMINS89 » Tue Jan 21, 2014 10:09 pm
X2
Postby Tacoclaw » Wed Jan 22, 2014 3:41 am
No idea, I bought it waaaaaaaay back as my first BHAF. It actually quieted the turbo almost completely, but the element inside of it wasn't nearly as big as the BHAF.
I'll go through my PB and stuff and see if I can find a part number. It was from Carquest.
