installed a 366 spring and truck dies when i press the pedal
Postby Joecochrane » Thu Jan 16, 2014 9:37 am
First post here so here's the back ground info. Truck is a 87 f350 4 door big dumb lift and big dumb tires. First gen 180hp bus motor factory air to water 727 trans gear vendors od (gear vendors is for sale) . Ground the hell out of pin, maxed the screw adjusted the linkage pushed the pump to the head and and installed a hx35. Yesterday I got my 366 spring in the mail and installed it. When I fired her up she revs to about 1500 and dies when I hit the pedal. I'm guessing I indexed the linkage wrong. I'll check after work is there any other thing that could cause this.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: installed a 366 spring and truck dies when i press the pedal
Postby RCCUMMINS89 » Thu Jan 16, 2014 10:37 am
Sounds like a linkage and fuel screw out of adjustment issue. Didn't get the lever in 180 out did you? I've heard of folks doing that, meaning when you push on the throttle it works backwards.
Postby Joecochrane » Thu Jan 16, 2014 11:17 am
Yeah got it figured out now just miss indexed my linkage.
Joecochrane
Postby Joecochrane » Thu Jan 16, 2014 11:18 am
Grinding on the throttle lever now so it won't contact the fuel supply line under wot
Joecochrane
Postby RCCUMMINS89 » Thu Jan 16, 2014 11:32 am
No need to grind it.... Either try and screw your fuel supply line in further.... Otherwise take it apart and bind the line just a little bit.
Postby Joecochrane » Thu Jan 16, 2014 12:00 pm
Tried both but I have my timing pushed to the head right now and I couldn't get the line bent out of the way. It's kinda tight right there.
Joecochrane
Postby RCCUMMINS89 » Thu Jan 16, 2014 12:11 pm
Ah...well whatever gets ya that full travel. ;)
Postby Joecochrane » Thu Jan 16, 2014 12:36 pm
Full travel out of the pump is easy but trying to get my tv linkage in the Trans in sync isnt workersng out.
Joecochrane
Postby tim curran » Sat Feb 01, 2014 6:33 pm
How did you fix your throttle did you have to take the pump apart again. Mine is doing the same thing after I just changed some seals
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Postby Joecochrane » Sun Feb 02, 2014 5:33 pm
No just had to take the throttle linkage off and reindex it.
Joecochrane
