Is the comp wheels the same??? I robbed the comp wheel off one of my hx35s for mock up of my 351 but I'm wanting to put the hx35 in my truck So I was thinking about using the h1c wheel if it was the same...
if not I'll pull the hx off and use the h1c for mock up. Also the turbine wheels are the same between the two correct???
