Fuel Pressure Gauge
Fuel Pressure Gauge
Postby dyne_79 » Sat Mar 15, 2014 10:16 pm
I have a 93 with a 5 speed, 167k on it. Is it recommended to run a fuel pressure gauge? I plan on ordering one and am coming across two types of pressure fittings to hook up the gauge. Do I need this auto meter 3279? http://www.amazon.com/Auto-Meter-3279-P ... el+snubber
or do I need this from Geno's http://www.genosgarage.com/12MM-CUMMINS ... yUzjoVhp2E
dyne_79
Re: Fuel Pressure Gauge
Postby Philip » Sun Mar 16, 2014 5:26 am
You need the one from Geno's.
Some pressure gages come all ready snubbed. I would hook the gage up and try it. I have a Isspro fuel pressure gage. It is snubbed.
Postby dyne_79 » Sun Mar 16, 2014 10:17 am
Without the fitting, where can you plumb into the fuel line?
dyne_79
Postby RCCUMMINS89 » Sun Mar 16, 2014 12:09 pm
I've personally never seen a snubber work........the only thing that has worked for me, leave air in the line. Air works as the ultimate snubber/damper.
Postby CumminsPower59 » Sun Mar 16, 2014 12:51 pm
My 91 has a snubber and isolator running to an Isspro R5604R. I used that same snubber when setting everything up. Everything works well ;)
Postby dyne_79 » Mon Mar 17, 2014 5:40 pm
I went ahead and ordered the snubber from geno's. What banjo bolt does it replace?
dyne_79
Postby dyne_79 » Tue Mar 18, 2014 4:33 pm
Anyone? I'm having trouble getting a clear answer searching. Must fuel pressure gauge write ups are on p pump motors
dyne_79
Postby PToombs » Tue Mar 18, 2014 4:43 pm
The one coming out of the filter head. It will be the one towards the front.
Postby 1992gen1_fan » Thu Mar 20, 2014 6:38 pm
I'm using a needle valve as a "snubber". It works good, but leaving air in the line works about the best atleast until the line fills up with fuel and makes its way to my gauge(mechanical non-isolated).
1992gen1_fan
Postby RCCUMMINS89 » Thu Mar 20, 2014 8:55 pm
I've been fortunate enough to never have the air leave the line.... not entirely sure why though.
Postby 1992gen1_fan » Thu Mar 20, 2014 10:32 pm
I'd think a higher mounted gauge might keep air in the line longer. My gauge is mounted kind of low, where the ash tray was.
1992gen1_fan
Postby DodgeFreak » Fri Mar 21, 2014 5:01 am
1992gen1_fan wrote:I'm using a needle valve as a "snubber". It works good, but leaving air in the line works about the best atleast until the line fills up with fuel and makes its way to my gauge(mechanical non-isolated).
I'm using one also, I've the genos snubber with a needle valve snubber, but my gauge is a 3 in 1 glow shift so I'm not sure how well it works since I can't really see the numbers bounce like you can the needle with a mechanical.
