Adding I/C Parts to a Non-I/C Engine
Postby ArtBee » Wed Apr 09, 2014 2:47 am
Hello everyone.
Recently got a very clean 91 Non- I/C D250, 727 truck. I also happen to have a 92 I/C parts truck. Main goals for the truck are fuel mileage/torque/towing 6,000 pounds behind it.
To switch it over to an I/C can I just change the turbo/tubes/Inter Cooler/Radiator Support/Radiator and be done with it or would I also have to change the injectors and make any changes to the Injection Pump?
I have a Diamond Eye 4" system with muffler for it. What should I set the I/P lift (timing) at for best towing?
Thanks
Art
1993 W350, 1991 D250 (non IC), 1969 Plymouth GTX, 1961 Chrysler 300G, 1966 Chev BelAir
ArtBee
Re: Adding I/C Parts to a Non-I/C Engine
Postby RCCUMMINS89 » Wed Apr 09, 2014 11:02 am
No need to change injectors or the pump.... just everything else you listed.
Postby PToombs » Sat Apr 12, 2014 6:29 pm
And the thermostat housing and upper hose.
