Manual Shut off indexing
Postby 89dudney » Wed Apr 23, 2014 6:58 am
My pump was resealed a month or so ago and my manual fuel shut off lever was indexed in the wrong location. I tried to turn my pump up a little bit after it was resealed and when I turned the fuel screw in one turn, my truck was runaway. I turned the truck on and it went full throttle. I had a buddy standing there with a board and we got it shut down. As of right now it is one turn lower than stock. What I am needing help with is re-indexing the manual fuel shut off into the correct location. I do not have anything to reference off of. Thanks in advance.
I like my truck more than I like 99.9 percent of people...
89dudney
Re: Manual Shut off indexing
Postby dpuckett » Wed Apr 23, 2014 3:00 pm
Remove your shut off lever and return spring.
Turn the shaft with your fingers in the direction it would normally turn to shut down, til you feel it bump the gov assembly. You will want to install the shut off lever on the NEXT set of splines after you bumped the gov. This will ensure adequate pressure against the governor when shutting it off.
I had a pump shop do tht many years ago on my mom's jalopy. It was a year or so later when I discovered it. That, combined with 2 injectors from a set magically fixing themselves while sitting on the shelf for a year, has ensured I will not be patronizing that business again.
Postby 89dudney » Thu Apr 24, 2014 6:23 am
So I dont have to remove the pump top to fix this issue?
89dudney
Postby dpuckett » Fri Apr 25, 2014 10:20 pm
I didnt have to.
Postby bgilbert » Sat Apr 26, 2014 7:00 am
What makes you think it is indexed wrong? Cause it wouldn't shut the fuel/truck off when it was at runaway?
Bill Gilbert
bgilbert
Postby 89dudney » Sun Apr 27, 2014 11:48 am
Because before the pump was resealed I could turn the truck up and had 2 turns on the fuel screw, and after it was resealed i couldn't go more than 3/4 turn and it would runaway
89dudney
Postby bgilbert » Sun Apr 27, 2014 1:18 pm
89dudney wrote:Because before the pump was resealed I could turn the truck up and had 2 turns on the fuel screw, and after it was resealed i couldn't go more than 3/4 turn and it would runaway
Could the fuel screw not been put back in the same location after reseal? How many threads are now sticking out? Keep in mind, not all pumps are the same or act the same after tweaking them, and once the fuel is turned up so much the shutoff lever can be ineffective.
bgilbert
Postby 89dudney » Sun Apr 27, 2014 4:49 pm
I backed it out half a turn. I will count the threads. How many should be sticking out?
89dudney
Postby CumminsPower59 » Mon Apr 28, 2014 5:32 am
Depends on the pump. Usually it's four to six threads that are exposed when the collar is on the screw IIRC...so maybe eight to ten?
Postby Tacoclaw » Mon Apr 28, 2014 5:45 am
Maybe the linkage is indexed wrong? If you bottom the fuel screw before it runs away, you can bump a spline on the throttle shaft and it'll move something in there.
Postby CumminsPower59 » Mon Apr 28, 2014 11:24 am
More or less. Index should be like this :
Postby PToombs » Mon Apr 28, 2014 4:46 pm
Damn that's a good picture Ike! 8)
Postby 89dudney » Tue Apr 29, 2014 6:17 am
I think I got it. I turned it all the way to the right, and then I put the lever on the shaft, turned it back to normal position plus a spline and the truck acts totally normal now.
89dudney
Postby CumminsPower59 » Tue Apr 29, 2014 11:58 am
Thanks Pete!
Good job Daniel, I knew you could do it ;)
Postby 89dudney » Wed Apr 30, 2014 6:28 am
Thanks guys. Its runnin good now, other than the fact that I have no adjustment in my fuel screw. A 1/4 turn in from "stock" ( where the fuel screw was when I got the truck) makes the truck self-rev. I dont know what I can do to fix it but It would be nice to bury my pyro quicker. :D :D :D
89dudney
