New injectors now engine won't run???
Postby 89cumburb » Mon Apr 28, 2014 9:49 am
Ok so I put new 5x14 injectors in my engine and now it won't start I have noticed from bleeding the lines and having fuel sit on top of the injectors some have air escaping??? The engine will fire every now and then but won't run dumps wire smoke a lot if it also it will run on either but as soon as you take it away it dies??? Any ideas please help :bh: :bh:
89cumburb
Re: New injectors now engine won't run???
Postby RCCUMMINS89 » Mon Apr 28, 2014 11:08 am
Did you do anything to the pump at the same time?
Postby 89cumburb » Mon Apr 28, 2014 11:38 am
Yes I had the pump out to do a gov spring
89cumburb
Postby RCCUMMINS89 » Mon Apr 28, 2014 12:05 pm
Ok, cuz it sounds to me like... the indexing or fuel screw isn't in the right place. Meaning it isn't getting enough fuel.
What mark did you set your indexing to?
Postby 89cumburb » Mon Apr 28, 2014 1:14 pm
When I had the pump out I had everything locked so I don't really think any of the timing could have been changed I also had the front cover off to do a gasket and I never saw any timing marks I'm assuming that's what you mean by indexing?
89cumburb
Postby cummins32 » Mon Apr 28, 2014 1:43 pm
Nope, he means the throttle shaft indexing on the pump it self, its what the gov spring connects to on the left side.
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Postby 89cumburb » Mon Apr 28, 2014 4:53 pm
Does that have to be re set when you do a gov spring? I never touched it
89cumburb
Postby PToombs » Mon Apr 28, 2014 5:06 pm
Sometimes it does. When I did mine I had to move it one notch because it wouldn't start unless I had my foot on it. Some guys have to move it a notch the other way, because it starts at 1/2 throttle or so.
Just to be clear, we are talking about the throttle lever on the shaft that the gov spring attaches to underneath.
There is a great pic of the index marks here; viewtopic.php?f=1&t=15779
Postby SNOOT » Tue Apr 29, 2014 7:57 am
Did you take the pump all the way out of the truck?
If you did take it out did you turn the engine over at all when you had the pump out?
1993 W350
SNOOT
