Bouncing Throttle
Bouncing Throttle
Postby 89dudney » Wed May 14, 2014 6:17 am
What would cause the throttle to be "bouncy" in third gear. When I leave it in 2nd and drive with higher RPM's, it doesnt do anything, but when I shift into 3rd it'll bounce. My foot will stay constant on the accelerator pedal, and it will make the truck lurch and jump. When I put it in 4th, it goes away. The bouncing is worse when I downshift to third. Help?
I like my truck more than I like 99.9 percent of people...
89dudney
Re: Bouncing Throttle
Postby DodgeFreak » Wed May 14, 2014 9:50 am
wonder if its a the gov acting up?
Postby 89dudney » Wed May 14, 2014 11:55 am
Would that also be part of why it self-revs in second gear and neutral? Hold it quarter throttle and it will go to the moon.
89dudney
Postby bgilbert » Wed May 14, 2014 3:38 pm
Fuel screw is turned up too much.
Bill Gilbert
bgilbert
Postby RCCUMMINS89 » Wed May 14, 2014 6:17 pm
Yep.... I have found the same as Bill is saying.
Postby 89dudney » Thu May 15, 2014 6:15 am
Not questioning what you guys are saying, but wouldn't the RPM level hang up there if it was too much fuel?
89dudney
Postby CumminsPower59 » Thu May 15, 2014 6:32 am
Its past that point. If it is self revving, turn it back until it won't do it anymore.
Postby DodgeFreak » Thu May 15, 2014 10:01 am
is it more noticeable since his is non ic and 5spd??? more so the non ic part with the bigger injectors
Postby 89dudney » Fri May 16, 2014 6:16 am
Well the other thing it does is when I rev it clear against the governor spring (366 spring) it pops and almost "cackles" when the rpm level comes back down. What would cause that? same thing? :shock:
89dudney
Postby dpuckett » Sat Jul 26, 2014 4:38 pm
The "self revving" at quarter throttle is just the nature of the beast of a non-IC pump. My 91 did it, Bill's 600hp 89 did it, my current truck does it now that it has a 114 pump. Get it to the rpm of peak torque, and it takes off. As long as the rpm comes right down you are ok.
Is your throttle bouncing at lighter throttle position in 3rd gear? I.E, when you mash it in 3rd, does it do it? Or is it more an issue when trying to maintain ~25mph in 3rd?
