What do Yall use for engine paint ?
Postby jethro » Mon Jul 28, 2014 8:10 pm
My engine is fairly clean- but the previous owner rattle-canned what appears to be flat black hi-temp paint all over it.
I have to say it really makes a good engine look like crap ! Have the front cover off for KDP fix so I stripped the cover.
Is there off-the-shelf engine paint sold by cummins (the crème colored stuff) having the correct temperature resistance ?
Do the auto paint stores have a hi-temp base to make it up to the correct color ?
Don't want to put something on it that will come off later !!!!!!
Tim
jethro
Re: What do Yall use for engine paint ?
Postby jethro » Wed Jul 30, 2014 10:53 pm
HEY !!!
I actualy found the correct paint at O-Reilleys auto parts- rattle cans of hi-temp engine paint.
Still need a quart- but that gets me started !
jethro
Postby PToombs » Thu Jul 31, 2014 5:25 pm
A quart! :shock: Are you putting it on a 1/2 inch thick? :lol:
Postby dazedandconfused » Thu Jul 31, 2014 6:02 pm
We use the high temp as a base then scuff it a bit and spray on the exact color in normal enamel. Has done well for me.
Postby ellis93 » Thu Jul 31, 2014 6:07 pm
PToombs wrote:A quart! :shock: Are you putting it on a 1/2 inch thick? :lol:
Only way to keep oil "inside" a cummins ;)
Postby jethro » Thu Jul 31, 2014 8:17 pm
No! Not a half inch thick.... Some of it I will be able to stray- but some areas will be easier to get up under with a
2 inch brush. A pint would do - but probably wont find anything anymore in pints......
I could brush the spray can paint if there was an easy way get it out of the can without a really nasty mess !
The spray can paint turned out beautifully for rattle can type.
I will try to clean the previous black with rotary wire brush. If that doesn't take it off- I figure it is stuck good enough
to paint over....
Tim
jethro
