RCCUMMINS89 wrote:What are you looking for? Stock replacement, or a performance injector?
oldestof11 wrote:It's EBay. You'd be better off spending money on a known good vendor.
DMan1198 wrote:It's not the seller that's the issue. It's that eBay injectors and turbos are not usually very good quality. The hungry diesel can get you 9mm injectors at a reasonable price that are genuine Bosch, so they'll last decent (certainly longer than Chinese stuff)
oldestof11 wrote:You won't get a new 9mm anywhere. You can get the 9->7mm adapter and run whatever you want.
RCCUMMINS89 wrote:We sell 5x12 9mm tip VCO, genuine Bosch injectors for $375 plus cores. Majority of folks decide to just run the marine 370s (5x12.8ish) injectors which run $425..... which is why the 9mm are not on the site.
