good injectors?????
good injectors?????
Postby manostihl » Wed Jan 28, 2015 11:43 am
manostihl
Re: good injectors?????
Postby oldestof11 » Wed Jan 28, 2015 2:48 pm
It's EBay. You'd be better off spending money on a known good vendor.
Postby RCCUMMINS89 » Wed Jan 28, 2015 2:57 pm
What are you looking for? Stock replacement, or a performance injector?
Postby manostihl » Wed Jan 28, 2015 4:34 pm
RCCUMMINS89 wrote:What are you looking for? Stock replacement, or a performance injector?
i would like a better than stock injector but really just need to get the truck back on the road as she is my primary vehicle. either way nobody that i can find makes new 9mm tip injectors i can get mine rebuilt for 390 plus 42 bux to test them id like to do better than that but i realize you get what you pay for. its just funds are really tight and im not entirely sure this is my problem i hope it is though
manostihl
Postby manostihl » Wed Jan 28, 2015 4:40 pm
oldestof11 wrote:It's EBay. You'd be better off spending money on a known good vendor.
they have pretty good feedback though
manostihl
Postby DMan1198 » Wed Jan 28, 2015 4:50 pm
It's not the seller that's the issue. It's that eBay injectors and turbos are not usually very good quality. The hungry diesel can get you 9mm injectors at a reasonable price that are genuine Bosch, so they'll last decent (certainly longer than Chinese stuff)
Postby manostihl » Wed Jan 28, 2015 4:53 pm
DMan1198 wrote:It's not the seller that's the issue. It's that eBay injectors and turbos are not usually very good quality. The hungry diesel can get you 9mm injectors at a reasonable price that are genuine Bosch, so they'll last decent (certainly longer than Chinese stuff)
i see what you mean ill check them out thanks
manostihl
Postby oldestof11 » Wed Jan 28, 2015 5:02 pm
You won't get a new 9mm anywhere. You can get the 9->7mm adapter and run whatever you want.
Postby RCCUMMINS89 » Wed Jan 28, 2015 5:26 pm
We sell 5x12 9mm tip VCO, genuine Bosch injectors for $375 plus cores. Majority of folks decide to just run the marine 370s (5x12.8ish) injectors which run $425..... which is why the 9mm are not on the site.
Postby manostihl » Wed Jan 28, 2015 8:12 pm
oldestof11 wrote:You won't get a new 9mm anywhere. You can get the 9->7mm adapter and run whatever you want.
probably wont have the extra 40 to spend just want some i can drop in and run
manostihl
Postby manostihl » Wed Jan 28, 2015 8:14 pm
RCCUMMINS89 wrote:We sell 5x12 9mm tip VCO, genuine Bosch injectors for $375 plus cores. Majority of folks decide to just run the marine 370s (5x12.8ish) injectors which run $425..... which is why the 9mm are not on the site.
well if i can sell some things i will probably go that route. just may have to sell the rims off of the hot rod :(
manostihl
Postby MMeier » Wed Jan 28, 2015 11:02 pm
$190 for a set of "new" injectors, think I would be very leery of such a thing !! Check out Red Oak Diesel out of Iowa, been running those for quite some time now . Same power increase as the PODs I had, with out all the damn smoke !!
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
