Timing Dial Part #
Timing Dial Part #
Postby Collers9640 » Sat May 18, 2019 8:57 am
Does anyone know where I can get the correct injection pump timing dial. FSM says to use 3377259 but I can’t find one and don’t know what to get
Collers9640
Re: Timing Dial Part #
Postby Philip » Sun May 19, 2019 6:21 am
Most tools listed in the FSM is supplied form a company called OTC.
Postby PToombs » Mon May 20, 2019 4:47 pm
I got one off e-bay for a VW with a VE pump, works great! The dial is in millimeters, it works ok for me. You can find them in inches also.
Postby 12valve95 » Mon May 20, 2019 5:36 pm
PToombs wrote:I got one off e-bay for a VW with a VE pump, works great! The dial is in millimeters, it works ok for me. You can find them in inches also.
https://www.ebay.com/i/382424528428?chn=ps Here is a link to this type.
12valve95
Postby 12valve95 » Mon May 20, 2019 5:38 pm
https://www.dencodiesel.com/products/ve ... nco-diesel
...and another option which seems to be a little more Cummins specific with instructional video apparently...(dial indicator not included)
12valve95
Postby Collers9640 » Sat Jun 08, 2019 10:11 pm
I gonna have to show my ignorance here because I’m a little clueless... Is there a certain adapter I need for the dial or are all ve pumps the same
Collers9640
Postby PToombs » Thu Jun 13, 2019 1:44 pm
All I've seen are the same. That being said............ ;)
