Valve adjustment, power changes
Postby garywj » Wed Feb 06, 2008 8:54 pm
Thanks for the info on the valve adjustment. My truck has 200,025 miles on it and I wonder if it has ever been adjusted before. After adjusting the valves, I turned the fuel screw up about a turn and a half. WOW!!! It runs way better now. More power, sooner. :lol: It seems to idle a little fast now, but I can see the power potential these engines have. My question is, leaving everything else stock. Would a smaller turbo housing be of any benefit? Also, would replacing my stock muffler with strait pipe help? Thanks for all your help! :)
92 w-250 all stock so far.
garywj
Postby Philip » Wed Feb 06, 2008 11:10 pm
Going to a 16cm housing from the 21cm it came with would be a good inprovement.
I didn't see any gains when I droped the muffler on the stock 3" system. All it did was add noise.
Now going to a 4" system is another matter. It gives better spool up on the turbo and lower EGT's. That is another good upgrade.
Postby ford69557ci » Thu Feb 07, 2008 12:47 am
droppin the muffler may not add any power but it will drop the egt a little. if your an auto the 16cm will be ok but if your a manual then you will get better results out of the 14cm
ford69557ci
Postby cummins king » Thu Feb 07, 2008 6:20 am
you will realy love the housing upgrade, theres no benifit for removing muffler, unless you running bigger injectors
93 4X4 auto
cummins king
Postby Rug_Trucker » Fri Apr 04, 2008 9:46 am
So no muffler on my stock 93 will not help?
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Postby cummins king » Fri Apr 04, 2008 11:13 am
no just more noise
93 4X4 auto
cummins king
Postby dpuckett » Sat Apr 05, 2008 4:26 pm
I liked the 16 out of all of them that I have run (12-21), and I have had them all at one point or another. The 14 was just a little too restrictive- going to a ported 18 didnt change EGT at all, just dropped peak boost about 3-4psi.
I have had some trucks where removing the muffler seemed to help; others, not so much. It wont hurt anything. Going to a 4" system will help EGTs if you throw too much fuel at it- good for about 100deg reduction in peak EGt.
Daniel
Postby mhuppertz » Thu Apr 17, 2008 6:15 pm
Rug_Trucker wrote:So no muffler on my stock 93 will not help?
Saw the '72 Slant Sickness Duster in your sig. I have a hot 225 that I am looking for a fairly clean Duster body to jamb it into. Deisel prices are making me only break even now....
mhuppertz
Postby Rug_Trucker » Fri Apr 18, 2008 6:07 am
Check Desert Valley auto parts. They sometimes have some nice ones.
I have a rusty 74 that may get a 360 for commuting.
74 Dart 225 4 DR
93 D350 CTD auto
Rug_Trucker
