100psi intercoolers
100psi intercoolers
Postby NEW ERA » Mon Feb 11, 2008 9:50 pm
Now that I have your attention. How much interest would there be in them. Bar and plate 40% better flow than stock. 100psi rated stock replacement. they are 2 1/2 in and out. I have been asked about 3" and can do it but it will cost more and will be on a needed basis. They are going to list for about 900 but thinking about a group buy on this site for around 700.
Chuck
New Era Diesel
06 MEGACAB Sure its stock
Looking for a 1st gen toy!!!
NEW ERA
Postby ford69557ci » Mon Feb 11, 2008 9:54 pm
if you can do a 4" in out i would be interested because i am not sure what kind of boost the one i have will hold
ford69557ci
Postby NEW ERA » Mon Feb 11, 2008 10:08 pm
You need 4" In and out? Is this when you go to the twins? I should be able to do it but may have to make a couple of brackets when you fit. I see what I can come up with.
NEW ERA
Postby ford69557ci » Mon Feb 11, 2008 10:15 pm
yeah i sold my s 485 and am searchin for an s510 so i plan on movin alot of air. and if my small block chevy goes faster with 4" ic pipe then why wont the cummins?
ford69557ci
Postby burnt_servo » Tue Feb 12, 2008 3:31 am
burnt_servo
Postby flashgordon » Tue Feb 12, 2008 7:05 am
Chuck,
Most of us are looking for a better intercooler when we decide to install one or upgrade one that already has on.
The popular up grades is a P/S intercooler that has a 3" in/out and a 2nt gen intercooler that is much larger then the stock one. Has 3" tubes with a 4" in/out.
With That said, there is a lot more efficient (in stock intercooled spec') with an up dated design!.......and larger in/out tubes would be a plus.
My truck is a non intercooled design that i have installed a 2nt gen pipes and intercooler just recently.
So I'm not in the market for one right now............But a 2nt gen cooler will be what i will be looking for, when that day comes. ;)
flashgordon
Postby PToombs » Tue Feb 12, 2008 4:55 pm
The ones PDR has are stock in and outlets. I paid $700 for mine a couple years ago. They were special deals that Mark had someone building for him. He wanted the ends back so he could make new ones.
Postby TWorline » Tue Feb 12, 2008 7:05 pm
Chuck, count me in! :bounce: I will need one with 3" in/outs on it. Actually the f**d ps intercoolers are 3.25" in/out.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby GO OVRIT » Wed Feb 13, 2008 9:13 pm
I'd have been interested a month ago before cutting up a banks cooler to put 3" tubes on it.
GO OVRIT
