spooling HX40 with stock injectors?
Postby krazykarl454 » Mon Feb 25, 2008 8:44 pm
hey guys, im in abit of a pickle. im building an exhaust for my cummins swapped k30 chevy, and i dont want to have to do it again when i upgrade to the WH1E i have. and i dont have the money rite now for injectors. so i was thinkin about puttin the WH1E on now and buildin the 4" down pipe and and exhaust. i will have a fuel pin, 3200gsk, and intercooled. so my big question is will i be able to spool this thing ( will it be driveable), or am i just opening a can of worms? i plan on driveing this from NJ to NC quite often and probley b4 i can get injectors. All the info you can give me i would aprechiate. and what injectors would u recommend? this truck is goin to be mostly for towin another truck around and DD.
thanks alot- karl
86' GMC 3500 (cummins swap: hx40, POD's, I/C 5" exhaust) , custom 4-link front end, about 9-inchs of lift, dana 60 4.56s welded/ 14-bolt, 4.56s detroit. grooved 38.5 x16 TSLs, custom frt/Rr bumpers, 16.5 super sinlge welds
krazykarl454
Postby CumminsPride » Tue Feb 26, 2008 5:24 am
Does your WH1E have an 18cm or 16cm housing? The 18 is gonna be real laggy but I doubt it's gonna be any worse than the stock 21 and the 16 would probably feel like the 18 stock.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby krazykarl454 » Thu Feb 28, 2008 7:12 pm
ok where would the number be located. the only number i found was 19. think it could have a 19cm turbine?
krazykarl454
Postby cummins king » Fri Feb 29, 2008 7:24 am
i know with my hx40 i have no problem spoling it with stock injectors, with a 16cm exhaust housing
93 4X4 auto
cummins king
Postby ford69557ci » Fri Feb 29, 2008 4:59 pm
usualy with stock fueling the larger compressor wheel of the hx40 makes it fell like a factory turbo with a 21cm housing unless you do some work on the pump
ford69557ci
Postby krazykarl454 » Tue Mar 11, 2008 2:40 pm
hey guys has any one herd of a 17cm houseing for the WH1E or hx40? and would u know any part numbers? mite of found a deal on one if its for real
krazykarl454
Postby dpuckett » Wed Mar 19, 2008 8:17 pm
I've heard of 17 and 19cm housings on the HX40/H1E. They have the T4 inlet flange, though. More suqarish bolt pattern than the stock T3 pattern. There are adaptors, but they are spendy. Seems like I saw a homemade adaptor in bgilbert's shop a few weeks ago. I could be smoking crack, too.
Daniel
Postby krazykarl454 » Sun Mar 30, 2008 8:08 am
yea it had a T4 flange. i bought it, and it is alot smaller then the monster 21. i ended up makein my own adapter up fro mthe the T3 to T4.
krazykarl454
