Difference between Cummins 160hp & 180hp Ve pump
Postby Brutus_Marcus » Fri Mar 07, 2008 2:23 am
Hi,
I sorry if i am not supposed to be posting it here,and the dumb newbee question. Thanks in advance to everyone..
Its not particularly a Dodge question, but Is there really any difference in the Ve pump and Injectors between the 160hp and 180hp Cummins 6bt motor, both being intercooled. I know of a place that has a pile of these motors lying around and might have both the motors lying around. If there isnt any difference then i can pick either one and bomb it.
Regards,
Bikram
Brutus_Marcus
Postby cummins king » Fri Mar 07, 2008 6:37 am
i dont know the answer but i would really like to know what cam plate is in a 180hp ve, or if the just put the max power screw in, thats worth an extra 20hp
93 4X4 auto
cummins king
Postby JD730 » Fri Mar 07, 2008 7:03 am
cummins king wrote:i dont know the answer but i would really like to know what cam plate is in a 180hp ve, or if the just put the max power screw in, thats worth an extra 20hp
Probably the same or similar. I'm gonna say it all in the pump calibration, there might be some minor differences like delivery valve holder lengths.
Mike
The "Rattle Box"
JD730
Postby PToombs » Fri Mar 07, 2008 6:39 pm
20 horsepower? ;)
Postby oldestof11 » Fri Mar 07, 2008 7:21 pm
There is no 180 hp VE AFAIK but there is a 160 hp VE and a 180 hp P-Pump....
Postby Brutus_Marcus » Sat Mar 08, 2008 12:36 am
We have both the versions here(160hp &180hp). But just like you guys said, maybe they are the same bcoz not only is there a difference of only 20Hp but even the Torque difference is only about 60lb(160Hp/415lbft & 180Hp/470lbft).....
Thanks guys
Brutus_Marcus
