Question for KTA
Question for KTA
Postby peobryant » Thu Mar 13, 2008 1:21 pm
Brian, I have a question concerning my trucks air filter. My brother Patrick just came up to John Deere the other day in my '91 Dually. He told me to ask you about a BHAF. He said you use a dozer air filter but have to build some special brackets. So my question is can you tell me, or post pictures on how to do this? Thanks.
Postby PToombs » Thu Mar 13, 2008 3:54 pm
Big Honkin Air Filter? I thought everybody had one? ;) It's just a bigger filter put in the fender corner. You can make a mount of your own, or make an "Old Smokey" mount. All it is is a steel plate bolted to the fender edge with a hole in it for the air tube to go to. Most have pipe strapping or some such to hold the filter to it. If you do a search, you can get part numbers. Might even come up with a link to a pic of the mount.
Postby KTA » Thu Mar 13, 2008 6:48 pm
The filter I run is NOT a BHAF. I will look and get the part number maybe tomorrow, and will try to get a pic too if I can find a digital camera.
Postby cummins king » Thu Mar 13, 2008 7:38 pm
what was a big 5inch afe not big enough or somthing
93 4X4 auto
cummins king
Postby fasttalker83 » Mon Mar 17, 2008 10:13 pm
I have a 6in. inlet filter off of a CASE IH steiger is that to big...lol just figured you could never have enough air
fasttalker83
Postby cummins king » Tue Mar 18, 2008 5:42 am
on what turbo a hx60 it might be okay anything else its over kill
93 4X4 auto
cummins king
Postby flashgordon » Tue Mar 18, 2008 5:57 am
KTA wrote:The filter I run is NOT a BHAF. I will look and get the part number maybe tomorrow, and will try to get a pic too if I can find a digital camera.
So where's the pic's??? I thing you have us all curious now :P
Flash
flashgordon
Postby fasttalker83 » Tue Mar 18, 2008 2:17 pm
I have to take my camara to school on thursday with me i will snap some then oh and its only on a H1C/H1E hybrid I built ya its probably over kill but it looked cool figure it couldnt hurt and wanted to be unorthadox about it cuz my teacher is a by the book guy
fasttalker83
Postby bgilbert » Tue Mar 18, 2008 3:45 pm
Flash
Not to speak for Brian, but way back when I got the privledge to look under the hood :shock: and I seen the filter. It was simlar to the bhaf in size and construction. You know kta, it was probly a filter he found in the book that flowed as much or more as the ah19037 (bhaf) but was half the cost :lol: .
Bill Gilbert
bgilbert
