by KTA » Tue Apr 08, 2008 3:23 pm
use the adapter only, the rubber sleeve is for C-series applications so ignore it, and the o-rings go in the nuts on top of the injector to keep water and dirt from getting down in the injector bores around the body. If you look at the nuit you will see a recess where you push the o-ring in from the top side.
