hard starting?
hard starting?
Postby hassy21 » Thu Apr 10, 2008 8:48 am
Ever since I put my piston pump on my truck is sometimes lugging during start up. It blows out more black than the stock lift pump but it acts like the starter is goin out. Wondering if anybody had a problem like this before?
hassy21
Re: hard starting?
Postby flashgordon » Thu Apr 10, 2008 9:23 am
hassy21 wrote:Ever since I put my piston pump on my truck is sometimes lugging during start up. It blows out more black than the stock lift pump but it acts like the starter is goin out. Wondering if anybody had a problem like this before?
Before you replace you starter......check you positive battery cable.........
Mine had a lot of Resistance in it. There was no sign of corrosion, but when i strip the insulation off from it..........It was in there.
As far as the lift pump.......makes sure your connections are tight, on the suction side of the lines.
Flash
flashgordon
Postby PToombs » Thu Apr 10, 2008 5:00 pm
Did you use the high or low pressure lift pump?
Postby hassy21 » Sat Apr 12, 2008 2:37 pm
I got the part # from the piston pump conversion
hassy21
