holset HT60
holset HT60
Postby fasttalker83 » Wed Apr 16, 2008 7:06 pm
I was looking at a HT60 off of a N14 and wondering if they would bolt up to the 5.9 manifold just looked really close didnt know anyone done this or tried this
fasttalker83
Postby cummins king » Wed Apr 16, 2008 7:23 pm
lol, no not even close,
93 4X4 auto
cummins king
Postby fasttalker83 » Wed Apr 16, 2008 7:42 pm
ok thats fine but I can still make a hybrid out of it I think does it still have the 4-8mm bolts that hold it on the backside of it
fasttalker83
Postby cummins king » Wed Apr 16, 2008 7:58 pm
no its a big v bnd clamp, we are taking about a HT60 right, off of an Big
14l n14 cummins truck motor
your going to need a big set of injectors to spool that baby its going to be a laggy turbo i would get twins
93 4X4 auto
cummins king
Postby fasttalker83 » Wed Apr 16, 2008 8:02 pm
yes right see I have taken the H1E off a 10L cummins and made it a hybrid with a H1C now just wondering if I can do some expiermenting with a Ht60 off of a N14 they all have the Vband clamp on them just some holsets have 4 bolts to take out in the back and some dont to do a crossover, see I take the compressor wheels housings and everything off the front and change them over just wondering if a 60 would do the same
fasttalker83
Postby cummins king » Wed Apr 16, 2008 8:13 pm
a ht60 is a completely diffrent turbo, its frecking huge, the only mod that you can do to them is put a 23cm vs. the 28cm i think it is,
93 4X4 auto
cummins king
Postby dpuckett » Thu Apr 17, 2008 10:31 am
If you can get it cheap, why not run it under the H1C/E hybrid for a set of twins? I dont know if the HT60 is as efficient as the HT3B for our app, but it'd be worth a shot.
Daniel
Postby CumminsPride » Thu Apr 17, 2008 11:46 am
^^^^What He Said^^^^
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby RSWORDS » Sat May 24, 2008 6:18 am
fasttalker83 wrote:yes right see I have taken the H1E off a 10L cummins and made it a hybrid with a H1C now just wondering if I can do some expiermenting with a Ht60 off of a N14 they all have the Vband clamp on them just some holsets have 4 bolts to take out in the back and some dont to do a crossover, see I take the compressor wheels housings and everything off the front and change them over just wondering if a 60 would do the same
How hard was it to make the h1c/h1e hybrid? I have a brand new H1E sitting here an was told it is not worth anything. I wanted to hybrid it with the h1c but can't get any info on doing it. What all was involved? Thanks!
Bobby
RSWORDS
Postby fasttalker83 » Tue May 27, 2008 5:52 pm
The hybrid was not hard at all I had the exhaust housing off the C and took the whole front compressor assembly off the shaft and bolted on everything from the E to it bolts up directly with no problems and no problems in balancing as well
fasttalker83
