pump linkage lever
pump linkage lever
Postby el gringo » Fri Apr 25, 2008 6:28 pm
The spring and the pin it pushes on, are about to wear through. This is the lever assembley on the fuel injector pump, that rotates from throttle linkage . Dodge can't help other than selling a new pump. Are these parts available, and from where. Thanks for the help
93 d350 5.9 cummins/5sp
el gringo
Postby PToombs » Sat Apr 26, 2008 4:36 pm
Any Bosch authorized pump shop. I'll warn you though, it's $50 for 1 lever and $75 for the other. Or pretty close, it was a couple years ago I checked on them. The spring was only about $20.
I welded up the pin, then sanded it smooth with emery paper. No f'in way I was paying that much for a lever! :shock:
I did buy the spring. ;)
Postby el gringo » Mon Apr 28, 2008 4:04 pm
thank you PT. I found a shop that will get me the spring, and was able to save the lever with my TIG. thats $$$ left in my pocket. Now on to the next problem
el gringo
Postby PToombs » Mon Apr 28, 2008 4:37 pm
el gringo wrote: Now on to the next problem
If the next problem has anything to do with too much beer, I can help with that too! ;)
Postby SNOOT » Tue Apr 29, 2008 8:02 am
This is the only picture I have of my setup but you can see its an improvment over stock.
Parts can be purchased at http://www.mcmaster.com/
1993 W350
SNOOT
2muchbeer
Postby el gringo » Wed Apr 30, 2008 4:36 pm
Hey Pete, if you are ever on I-10 and US-95 I alway have cold beer.
I do have more questions though. I want to adjust my valves and wonder the best way to hand turn the engine in order to find tdc.I don't own any tool to do this. Also how much force does it take to push in the timing pin. Mine seems stuck.
Thanks again. el gringo :D
el gringo
Postby PToombs » Wed Apr 30, 2008 5:44 pm
Aaayy, gringo! :lol: What I usually do is grab the head of the pin with channel locks, and yank it right out. Then I look in a mirror thru the hole and watch for the depression in the cam gear. Waaayyy easier I think. Then you just push it in a little ways, after lubing the o-ring. ;)
I usually put a socket on the balancer bolts and turn it that way, gently. If it starts to turn hard, wait a minute for compression to bleed off. I could bring the barring tool home from work, but I never remember. :roll:
I appreciate the beer offer. I have a bunch of them so far. Some day I'm gonna collect, drive cross country and get drunk all the way! Might take me a month or 2. :lol:
Postby el gringo » Fri May 02, 2008 4:36 pm
Your the man Pete. It worked just the way you said. I now have a better tuned truck. This one saved me lots of beer money. Thank you for the great help. Your beer will be here when you get here.
el gringo
el gringo
Postby PToombs » Fri May 02, 2008 5:51 pm
Glad it worked for you!
I'll be by in a couple years for a beer! :jumpsmile:
