Quick question.
Quick question.
Postby dodgetkboy78 » Sat May 03, 2008 9:55 am
This add has been on craigslist for a couple weeks now, and I was wondering if it is something I can use?
For sale used cummins marine 6b 250 thru 370 hp 1992 short block. this short block has pistons and crank but no cam or lifters $100.00. can be rebuilt or parts. also for sale is a used running take out cummins marine 250hp 6b 1989 long block with lucas cav rotary injection pump, injector fuel lines and injectors $300.00. call ron at
dodgetkboy78
Postby dodgetkboy78 » Sat May 03, 2008 10:30 am
While I am at it, will a turbo and ex manifold off of a 04 fit on my 92????
Theres all kinds of goodies on craigslist this morning.
dodgetkboy78
Postby nooblet » Sat May 03, 2008 12:16 pm
Is that a VE pump on the second one? $300 is a steal if it is.
Chris
nooblet
Postby dodgetkboy78 » Sat May 03, 2008 1:20 pm
I don't know, whats a Lucas CAV pump? I also wonder if the injectors are something I can use?
dodgetkboy78
Postby PToombs » Sat May 03, 2008 4:18 pm
It is what it says it is, Lucas CAV pump. They were used in ag and industrial 5.9's a lot. Less HP than the VE puts out though.
Both of those are steals for what they are.
The injectors are the same, but being it's an 89, they are 9mm.
The manifold from the 04 won't work, ports are shaped different.
Postby oldestof11 » Sun May 04, 2008 11:44 am
AH Pete, I beg to differ.
Get exhaust manifold gaskets for a 12v and port the 04 to match it top and bottom and it works like a charm! I have a 05 manifold on my Burb and it work BEAUTIFUL!!!
Postby cummins king » Sun May 04, 2008 12:28 pm
but isnt the newer stuff ovel or somthing like that
93 4X4 auto
cummins king
Postby PToombs » Sun May 04, 2008 2:29 pm
Jon, I realized that after I posted it. Figured I'd let it be. The other thing is the turbo mount/ exit sits in a different spot.
CK, yeah, the ports are shaped different. If you go to the ATS or HTT website, you can see both manifolds, and compare the ports.
