this may sound crazy
Postby 89silverbullet » Wed May 07, 2008 6:53 pm
I have a crack in the hose to my filter :cry: stupid friend bent it when i was not looking. to bad to repair! where can I get a new intake hose? P.S. cummins in san antonio turned me away and said dodge :shock:
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Postby Begle1 » Wed May 07, 2008 8:46 pm
A popular performance-minded aftermarket modification is to replace the piece of flex hose with a straight metal pipe and two 45 degree silicone boots. I've seen a few guys do that, usually in conjunction with an Ole Smokey BHAF mount.
I don't know how that's supposed to flow better than the stock flex tube, but if the stock tube's broken it's probably cheaper to go that route.
1st gen Cummins' in junkyards are hens teeth.
Postby 89silverbullet » Thu May 08, 2008 2:54 am
where can i get the bhaf mount and filter? :scratch:
89silverbullet
Postby SChandler » Thu May 08, 2008 8:51 am
This is the template most use: http://www.dieseltruckresource.com/faq/faq.php?display=faq&nr=160&catnr=20&prog=1&lang=en&onlynewfaq=1. It can be made from about 18 gauge or so sheetmetal. The filter is here: http://www.fleetfilter.com/Store_ViewProducts.asp?Cat=53. You want the Napa 2790 (Wix 42790). It can be cross referenced to other brands too. I just found this site: http://www.vulcanperformance.com/servlet/the-8%29-Filters/Categories. They have the BHAF filter a couple dollars less than the NAPA site does and they have the Outerwears cover for it as well. You'll want the Outerwears cover, it helps keep the big chunks from getting to the filter (makes the filter last longer) and it helps keep water off of the paper filter element.
SChandler
Postby SChandler » Thu May 08, 2008 9:00 am
This is the other site I was looking for: http://www.cumminsdatabase.com/read.php?id=15. Lots of different part numbers for BHAF's.
SChandler
Postby nooblet » Thu May 08, 2008 1:54 pm
If you do what Begle suggested you will need to by a 4" to 3" conversion piece. Your H1C is a 3" intake and a BHAF will be 4".
I would highly suggest going the BHAF route, I noticed quite a difference. I still am using the stock hose though.
Chris
nooblet
Postby 89silverbullet » Thu May 08, 2008 10:54 pm
are there any bolt on 3- 4" conversion pieces
89silverbullet
Postby GO OVRIT » Fri May 09, 2008 3:43 am
Go to this site http://airflo.com/index.html They've got what you need.
GO OVRIT
Postby nooblet » Fri May 09, 2008 9:52 am
89silverbullet wrote:are there any bolt on 3- 4" conversion pieces
Yes, use ovrit's link. They make the conversions in the soft parts.
I would suggest trying to build as much of the plumbing out of 4" as you can so if/when you ever upgrade your turbo you won't have to trash the whole set up.
Chris
nooblet
Postby 89silverbullet » Mon May 19, 2008 8:26 am
go to the pluming department in lowes and you will find everything you need. do it yourself! gotta love it 8)
89silverbullet
Postby Rug_Trucker » Mon May 19, 2008 6:47 pm
89silverbullet wrote:go to the pluming department in lowes and you will find everything you need. do it yourself! gotta love it 8)
I work for Lowes, I get 10% off everything............. :P
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Postby 89silverbullet » Tue May 20, 2008 11:03 pm
lowes sells a 3-4" adapter for the bhaf upgrade. and a hose for your washing machine. 20 bucks later i had every thing
89silverbullet
Postby Rug_Trucker » Wed May 21, 2008 9:24 pm
anyone got a pic of this BHAF?
74 Dart 225 4 DR
93 D350 CTD auto
Rug_Trucker
Postby 89silverbullet » Thu May 22, 2008 5:38 pm
89silverbullet
Postby PToombs » Thu May 22, 2008 6:03 pm
That's the BHAF, in a 2nd gen application. ;)
