Intercooler Elbow - Please Help!
Postby justagoodolboy » Fri May 16, 2008 2:22 pm
Guys, I have searched until I am beyond pissed, but turning to my 1st gen brethren for help!
The aluminum elbow that comes out of the compressor and 90's into the 1st intercooler boot has busted and I obviously have a major boost leak. Problem is its the lip that holds the seal in place broke off around a quarter of the way, so there is no way to weld it or anything.
I cannot find it through PDR, HTT, or any other diesel shops I have dealt with in the past both online and locally. I got the PN from it and called my local Cummins shop where I am buddies with the parts manager and all he could find was what he called a intercooler boot something or another for $498. He suggested I called the dealer and I called two different ones here who say the only way to get that part from them is to order an entire turbo.
Does anyone know where to get this part or have one laying around they would part with? I am dead in the water and need my truck.
Thanks!
1992 D350 xCab
5spd, 3200 Spg, BHAF, Slight Pump Mods
justagoodolboy
Postby Paccool » Fri May 16, 2008 3:29 pm
I had the same thing happen on my 93. I was having some work done at Ponci's Diesel and when he took the connector off it fell apart. He took the flanged section off a different sized housing, cut off the bad section on my housing and welded the other one on. Has been fine ever since (about two years now).
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby NYCEGUY01 » Fri May 16, 2008 7:15 pm
I have one off a 2nd gen. Same thing except it uses a larger hose size on the boot.
96 chevy 3500 4x4 dually. 1st gen Cummins ,nv4500.
NYCEGUY01
Postby bgilbert » Fri May 16, 2008 8:20 pm
MAKE ME AN OFFER :D !
Bill Gilbert
bgilbert
Postby Richie O » Sat May 17, 2008 9:07 pm
I just got a second gen one for my S300 on my 89. It has a 3 inch outlet and is only 70 degrees not a full 90. The part number is 3923178.
Postby justagoodolboy » Mon May 19, 2008 8:29 am
bgilbert wrote:MAKE ME AN OFFER :D !
Check your PM's.
1992 D350 xCab
justagoodolboy
Postby krazykarl454 » Mon May 19, 2008 7:57 pm
look on ebay man, i found a 90 degree one to 4" for 5 bucks, alot of holsets use the same size flange
86' GMC 3500 (cummins swap: hx40, POD's, I/C 5" exhaust) , custom 4-link front end, about 9-inchs of lift, dana 60 4.56s welded/ 14-bolt, 4.56s detroit. grooved 38.5 x16 TSLs, custom frt/Rr bumpers, 16.5 super sinlge welds
krazykarl454
Postby bgilbert » Tue May 20, 2008 6:59 pm
Like I told him, the 3" and 4", 2nd gen Dodge, industrial, Ford, Freightliner and other apps minus the 1st gen IC'd Dodge are very common and easy to come by. But the stocker he wants doesn't pop up very often. I have a few elbows laying around from various apps. I pass them up all the time at my local junkyard.
bgilbert
