so numbers i can expect
Postby 89silverbullet » Sun May 18, 2008 7:47 am
well if I do go and do this bhaf mod. What kinda numbers can i look at vs stock?
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Postby Begle1 » Sun May 18, 2008 8:12 am
Around stock... Plus a little...
Postby bgilbert » Sun May 18, 2008 8:41 am
I gained 2psi of boost going from a k&n stock filter replacement to the BHAF. I would guess 0-2psi of boost gain over stock.
Bill Gilbert
bgilbert
Postby 89silverbullet » Sun May 18, 2008 7:13 pm
would me playing with the pump mods help the power gain
89silverbullet
Postby cummins king » Sun May 18, 2008 8:15 pm
yes,
93 4X4 auto
cummins king
Postby 89silverbullet » Mon May 19, 2008 4:44 am
on a level of 1-10 how hard is it to put a hx40 in place of my h1c
89silverbullet
Postby CumminsPride » Tue May 20, 2008 10:55 am
Do you have tools or just a craftsman set and some box end wrenches? With a good source of tools and a good welder and some 4" pipe you can swap the turbo out and build the down pipe and exhaust and be done in 4-5hrs.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Richie O » Tue May 20, 2008 8:07 pm
CumminsPride wrote:Do you have tools or just a craftsman set and some box end wrenches? With a good source of tools and a good welder and some 4" pipe you can swap the turbo out and build the down pipe and exhaust and be done in 4-5hrs.
It takes me 4 to 5 hours to open the tool box!!!! We are waiting for Philip to put his 40 on. :roll:
